O ring block questions .
Old Jul 13, 2006 | 11:53 PM
XtremeLover1999's Avatar
Default O ring block questions .
Sup , I would like to know what head gasket do you use with an o ringed block and reciever groove in the head . My plan is to use the stage 2 or 3 head that I got on my APE 408 engine . I don't want to spend the money on new heads now . I can do all the machine work myself . I just finished line honing the mains from that engine which was around 2 thousand under the lowest tolerance and have only .0027 piston to wall clearance . So I have to redo the whole engine .
What i the biggest hp you guys have made with stock casting . The heads have 69 cc cnc'd chamber . My plans is to go twin turbo .
Thanx
