log headers vs. full headers
Old Jul 21, 2006 | 09:36 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
We made on a customers car a little over 650rwhp (~18psi)on an LT1 a few years back. BUT, at 14psi we had 45psi of backpressure. Swapping from log to a header style system dropped backpressure from 45 to 29. Car picked up a shade over 100rwhp. So something to think about....., also EGT's dropped down ~250deg.
Jose
Old Jul 21, 2006 | 10:01 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
Jose, was there any psi change on the inlet.?
Ricky
Old Jul 21, 2006 | 10:04 AM
LS1TECH Sponsor
None, the spring/WG was regulated to 14psi.
Old Jul 21, 2006 | 10:21 AM
TurboGibbs's Avatar
Originally Posted by bowtieman81
If we are discussing truck manifolds then they will support very large power. I was thinking of a log manifold where both banks feed into a single log.
I have a 4.8 truck manifold on the driver side which merges to a single log on the passenger side. I have put down 539rwhp 578rwtq in 95* heat with no meth, 16* timing and 10psi boost. Another 100-150rwhp should be possible when I get the meth hooked up, and crank the boost + cooler weather. There is a link to pics of my set-up in my sig. I know this is a truck but with this particular type of set-up space shouldn't be much of a factor.
And yes, Parish8 put down 1011rwhp with a single log set-up and truck manifold similar to mine. He had a T88. You can go to 1320video to see the vid of it.
Old Jul 21, 2006 | 11:21 AM
engineermike's Avatar
What was done with the downpipe and exhaust?
Mike
Old Jul 21, 2006 | 01:24 PM
LS1TECH Sponsor
Still stayed as a 3" and the exhaust was an SLP 2 on the left.
Old Jul 21, 2006 | 01:53 PM
That's interesting and doesn't reflect the results we got on mine versus the SBC 377.
Mine: 363 cid, log header, T76GTS, 3" downpipe, 3.5" exhaust over the axle, no muffler.
Results: 18 psi boost, 34 psi backpressure.
Airboat: 377 cid, tubular headers, T76GTS, 3.5" downpipe only 2' long, no exhaust or muffler.
Results: 18 psi boost, 26 psi backpressure.
Perhaps my log header is a better design than most. It's 3" in diameter and 3 of the tubes merge into it. Only #1 T's in at 90 deg.
Mike
Old Jul 21, 2006 | 02:13 PM
LS1TECH Sponsor
Mike
3" log .
This was a 2.5" log .
Old Jul 21, 2006 | 11:03 PM
MetallicaMatt's Avatar
Wait till heat transfer
yeah thats next, blah
Old Jul 22, 2006 | 01:05 AM
In my first year, when I was in Caluclus, everyone said it was a "weed out class" and it would get easier.
In my second year, when I moved on to Statics and Dynamics, everyone said they were "weed out classes" and it would get easier after that.
In my third year, when I took Thermo, Heat Transfer, and Fluids, everyone said they were serious business now that I got all the easy stuff out of the way.
In the last year, I took Machine Design and many people struggled, though I took to it well since it was crank-slider (crank, rod, piston), cam lobes design , etc. . .
The point is that no Semester of Engineering school is easy.
Mike
Old Jul 22, 2006 | 10:57 AM
Mike
I agree. I've taken thermo1, taking fluids, and still need to take heat transfer. I've taken Machine Design1 (we have 2 semesters of it) and everybody struggled. The teacher was hard core. Not many crank-slider problems in my class....bastard lol
Old Jul 22, 2006 | 12:09 PM
  #32
Eddiep's Avatar
Was this a TTi LT1 log setup?
Jose
