ATI procharger IAT sensor
Old Jul 20, 2006 | 09:19 PM
SVC707's Avatar
Default ATI procharger IAT sensor
i got my FMIC from EPP wasnt predrilled for the sensor. should i just drill a hole in my intake and put it like where the egr goes. or should i have the pipe drilled and weld a nut for it to thread into
Old Jul 20, 2006 | 10:13 PM
STALL UP's Avatar
you can also drill a hole and use the stock rubber grommet and IAT.
Old Jul 20, 2006 | 10:40 PM
SVC707's Avatar
you have to thread it so it doesnt blow out... stock grommet wont work, that would just be plug in then
Old Jul 21, 2006 | 04:33 AM
DJ's Z's Avatar
18 psi from F1 and mine hasn't blown out...just make sure you don't drill the hole too big. Get a good uni-bit and you should be fine.
Old Jul 21, 2006 | 06:46 AM
STALL UP's Avatar
I know for sure it will handle 15psi on a F1 408ci.
