Precision Turbos
Old Jul 21, 2006 | 08:04 AM
Formula 1's Avatar
Default Precision Turbos
What is difference between the GTQ and the GTS Precision turbos? Is there more lag with one over the other?
Old Jul 21, 2006 | 08:45 AM
PTE PETE's Avatar
Hi there,
The GTS wheel is a more efficent,higher flowing wheel for larger engines.Can spool slower in some cases,but can be worth upto 25-200HP depending on the turbo.
Pete
Old Jul 21, 2006 | 09:37 AM
Formula 1's Avatar
I picked out a Precision 72 GTQ in the the begining, for my PTK kit, to cut down on the lag and it will produce the power I'm looking for. Precision is telling PTK that the GTQ in a 72 is no longer available and they are giving me a GTS instead. Does anyone see any problems with going w/ that 72 GTS?
Old Jul 21, 2006 | 09:41 AM
DrTurbo's Avatar
LS1TECH Sponsor
None.....
Old Jul 21, 2006 | 09:48 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Hi Pete, welcome to the board. We talked a while back on the phone.
We are putting a GT47.88 on my 346ci in early August.
Old Jul 21, 2006 | 10:02 AM
PTE PETE's Avatar
What size is the engine & what mods?Should work well for you.Will help out the backpressure numbers at high boost.
Pete
Old Jul 21, 2006 | 10:07 AM
LS1Tech Co-Founder
348ci, ~8.25:1
AllPro CNC'd heads (similar to AFR225's etc.)
BS3
Old Jul 21, 2006 | 11:01 AM
Willem @ Fuel Injection Concepts's Avatar
the GTS is a GT42 turbine wheel.. better technology than the GTQ as well as larger
Old Jul 21, 2006 | 11:46 AM
Camaroholic's Avatar
Pete
He's got a new 9 to 9.5:1 forged 347 shortblock (from TSP), with a TSP "turbo cam" (I don't know the specs), and some old school GTP ported heads (that let him run 11.2's @ 124 NA, full weight, with a mild 226/226 cam - so I'd venture say they're pretty good not optimized for turbo, but they do have some good flow).
He is shooting for 550-600 rwhp. If he's man enough to handle it.
Old Jul 21, 2006 | 12:39 PM
PTE PETE's Avatar
The 72-GTS will handle that no problem its rated at a good 950 HP at the
crank.
Pete
Old Jul 21, 2006 | 06:25 PM
Formula 1's Avatar
It's all about hitting 4th gear, Andrew. Some can and some can't!
Old Nov 20, 2006 | 12:35 PM
THE_SUPRA's Avatar
...i just ordered a pt71-gts for my supra...i think its going to be a highway queen...or maybe a princess until i can get a good fuel setup/new pistons
Old Nov 20, 2006 | 03:10 PM
lcvette's Avatar
just out of curiousity and to maybe avoid an upgrade later.. doesn't anyone think the PT76GTS would be a wise choice in this situation? I think the 72mm unit has a MUCH narrower efficiency range and would actually be happier at higher boost levels as opposed to a 76mm at mild to moderate boost levels and same size body so fitment shouldn't be an issue?
Chris
Old Nov 20, 2006 | 03:41 PM
1INSANEGTO's Avatar
I am going with a T-76GTS on my Stock long Block GTO
