Video of roots blower setup on F-Body
http://www.tnfbody.com/forum/showthread.php?t=7512
You will find this note.. Roots blowers generally are used with carburetors or throttle body
fuel injection systems. Roots blowers are designed to work with fuel
passing through them and are not intended to be run “dry.”
Centrifugal superchargers typically run dry and are positioned in the
inlet stream ahead of the carburetor or fuel injection system. This is
why centrifugal superchargers are commonly found on late model
engines which use port type injection systems. Roots blowers, as a
result of the supercharger’s configuration, are not practical for use
on port injected engines."
The Teflon coating they put on the rotors gets warm if nothing cools it down.......
