BOV issues...
Old Jul 23, 2006 | 12:59 AM
RedTransAm's Avatar
Default BOV issues...
Is there a way to test a blow off valve? I am running a Tial 50 mm on my gt42 setup. When I first put the kit on, the bov was very loud. seemed to be working fine. Shortly after I lost a piston and put a new motor in. Since getting it back together I can't hear the same bov sound I did before, I really don't know if it is opening at all. anyone have any ideas?
Old Jul 23, 2006 | 02:05 AM
Boostaholic's Avatar
Well at 9psi when I let off the throttle its very audible, if you can't hear it then its probably not working.
Where is the reference hooked up to and did you change the spring?
Also, can you push it open a little with your fingers, you should be able to
Old Jul 23, 2006 | 12:09 PM
MiaSSmaro98's Avatar
well thats good to hear its loud i want one to,check ur vacumn source
Old Jul 23, 2006 | 12:18 PM
its not real loud
Old Jul 23, 2006 | 12:32 PM
RedTransAm's Avatar
yeah it wasn't real loud before, but at least audible. where do you get your boost reference from for the bov?
