IAT Placement on Turbo car?
Charlie
Why: It is the cleanest IAT reading before it actually enters the combustion chamber, especially when running meth. You want the PCM to see the IAT dropping due to the meth, you can then increase timing for more power. The colder the IAT's the more timing you can run.
My understanding at least.
J
Just don't spray through the MAF, as that will cause an issue.
You always want the aircharge temp sensor to register the actual air temps going into the motor..... no exceptions.
Ryan
Ryan
