Just installed SN-2000 (GEN ??)
Old Jul 23, 2006 | 09:49 PM
xxxtreme36's Avatar
Default Just installed SN-2000 (GEN ??)
just installed my sn-2000 on my 94 t/a. Now im leaking oil from my front cover gasket. I currently do not have a vaccum pump or a breather in a valve cover, would either one of these create less pressure on the gaskets. It only leaks hard when under a load. Any sugg are appre
Old Jul 23, 2006 | 09:56 PM
Boostaholic's Avatar
You need to get a breather and other crankcase venting stuff setup or you will also leak oil past your turbo seals
Old Jul 23, 2006 | 10:08 PM
xxxtreme36's Avatar
so if i got a breather and a vacuum pump would i be good to go?
Old Jul 23, 2006 | 10:22 PM
Yes long as your oil return is fine you should be ok, if not you may need a restrictor of some kind in your feed line.
Old Jul 23, 2006 | 10:27 PM
xxxtreme36's Avatar
what do you mean by oil return? how would i know if its ok? im kinda out-o-Da-loop on this stuff
