launching on boost -STS need help
Old Aug 1, 2006 | 08:39 PM
SSnakekiller's Avatar
Originally Posted by detroit_903
So A 2 step will not affect my tune correct?? Cause I have a stock engine with a safe tune for the turbo. Will I need to have the car re-tuned. I heard something about the timing and I remember the guy said not to mess with the timing or it will throw the tune off. I was thinking of buying the msd 2 step with the soft touch rev limiter
No and no...all it does is interrupt your firing...it is totally safe, just do it already!
The way I understand it is, you get spark every OTHER cycle instead of every cycle. So...instead of it firing every cycle like it would without the 2step, it skips every other cycle, creating the load which builds boost...
like this..
Spark:
2Step Off: fire, fire, fire, fire, fire, fire
2Step On: fire, , fire, , fire,
And as you can imagine, this process contributes to a lot of unburnt fuel, which somehow causes the load...
If I am wrong, someone please correct me...
Old Aug 1, 2006 | 10:05 PM
enginjoe's Avatar
Who sells a two step? Harlan doesn't any more. Anybody know?
Old Aug 1, 2006 | 10:59 PM
TURBO8's Avatar
Synergy Motorsports------------------------------------------------------------->
They are a sponsor
TURBO8's Avatar
I have one, It works great!
Old Aug 2, 2006 | 12:22 AM
vanillagorilla's Avatar
Do you know if Synergy's 2 step has a timing retard built into it?
Old Aug 2, 2006 | 05:46 PM
detroit_903's Avatar
Default re:
Okay I called the shop up today and they told me I had to run a msd ignition to run the msd 2 step. They said to run the 6a msd. But they make a msd btm. Since I have a sts turbo should I still go with a 6a??
Old Aug 4, 2006 | 12:58 AM
TURBO8's Avatar
What shop did you call? I have synergy's set up, it does not need a msd. I dont think it has timing retard thow. I will find out tomarrow.
Old Aug 4, 2006 | 01:49 AM
nick97ta's Avatar
if you are going with the MSD setup I would get the Digital 6-Plus Ignition Control - PN 6520, that is what I had and it worked very good...
Old Aug 4, 2006 | 11:56 AM
Cursed1's Avatar
vette=lack of penis
He has an LT1 and you have a LS1!
Old Aug 4, 2006 | 12:47 PM
JD_Z28's Avatar
Whats it take to install a 2 step. Sorry to get off topic.
Old Aug 4, 2006 | 01:28 PM
67Firebird455's Avatar
I think he's missing the point though... he said he's running cats with the STS... and he still wants to run a 2-step... BAD IDEA. Raw fuel into the cats are gonna cause MAJOR problems.
Old Aug 4, 2006 | 02:19 PM
  #32
I'm not running a cat.convertor with my STS set-up.
Old Aug 4, 2006 | 02:27 PM
  #33
Anybody have any idea how much one of these things runs from Synergy?
Any word on Harlan's new design? I emailed him in march and he said pre orders would start in April.
It seems to me you would really want to have the timing retarded to put extra load on the engine to build more boost. If I reatard the timing in my tune at that given rpm, then it's going to be a dog at that rpm all the time. regardless if I'm on the 2 step or not. It might be more benificial to hold out for Halan's unit if it does retard the timing.
Old Aug 4, 2006 | 03:00 PM
  #34
JD_Z28's Avatar
^^^Werd
Old Aug 4, 2006 | 03:16 PM
  #35
y2khawk's Avatar
I've hit a few bugs along the way, and had prior commitments that needed to be addressed first, but it's close to being complete. 4th round of prototypes is due in soon, then I can get a final assembly quote and pull the trigger.
options for timing retard, multiple limiter settings, soft touch limit selectable, plug-n-play, harnessing, etc
Trust me, I'm as anxious to get it out as some folks are to get it.
Old Aug 4, 2006 | 04:08 PM
  #36
Nice, that sounds like it'll be worth the wait.
Old Aug 4, 2006 | 04:21 PM
  #37
JD_Z28's Avatar
I won't one when you guys have them. Please let me know asap.
Old Aug 4, 2006 | 04:42 PM
  #38
Mr. Bungle's Avatar
That is going to rock!! Can't wait for this
