STS Turbo System
Old Aug 2, 2006 | 09:47 AM
RA071024's Avatar
Default STS Turbo System
Hi folk
What do you think about this (if i will buy a 98-02 T/A WS6):
http://www.ststurbo.com/ls1_camaro_dyno
The numbers sounds good but just 1sec faster in the quartermile or is it with the 5Psi Boost? And what if i upgrade this system with all options they offer:
http://www.ststurbo.com/turbo_system_options
or is modding the LS1 engine with other options (Cam, Gears, full exhaust, Subframe connecters etc. and more) better?
Old Aug 2, 2006 | 10:16 AM
1 BAD BIRD's Avatar
Might get more specific responses from the forced induction forum
But you should always bullet proof your drivetrain first. IMO
Bob S.
Old Aug 3, 2006 | 08:46 AM
SSnakekiller's Avatar
Originally Posted by White Cobra
Hi folk
We typically see a good solid 1 second increase with 5psi.
Old Aug 3, 2006 | 09:30 AM
ironexecutioner's Avatar
It's really an all in one sort of thing if you want best results.. you should have a cam thats made for forced induction, you definately will want a 12bolt rear, depending on the boost you are planning to run forged internals wouldn't be a bad idea either. I would suggest building the drivetrain before the poweradder.. or you might be building the drivetrain when you aren't prepared to do so.
Old Aug 3, 2006 | 09:32 AM
navymitch12's Avatar
assuming you can get traction
Old Aug 3, 2006 | 01:14 PM
2.0-2.1 60' typically...these are mildly mod'd low boosted cars
Old Aug 3, 2006 | 10:25 PM
yea i know...i am only running 8psi...
and i have traction issues big time..
2.2 short time is my best so far...but the track down here sucks with prep.....
