D1 belt alignment?
If so did you use the correct "HEX" Stand offs.
There are 2 different lengths that come in the kit. Depending on which drive you use 6 or 8 rib.
There is a foot note in the install manual on which to use. Very easy to miss.
Would tell you but don't have install manual at hand.
Why didn't he use the laser when he installed it? Is he just trying to **** you over? If he installed it and its not straight, make him fix it.
http://www.sjdiscounttools.com/laz91006.html
