Procharger pulley alignment?
Old Aug 9, 2006 | 10:35 AM
Blank's Avatar
Default Procharger pulley alignment?
Is there another way to line up the pulleys without a laser?
Old Aug 9, 2006 | 08:24 PM
EPP's Avatar
EPP
You can normally install the blower belt, and run the engine at idle, and tell if the belt is starting to ride to one side of any of the pulleys. Bob
Old Aug 10, 2006 | 08:28 AM
wicked_95z's Avatar
I used a metal frame construction level. Laid it across both pullies.
Old Aug 10, 2006 | 09:38 AM
Blank's Avatar
if the pulleys are out of line how do i line them up
Old Aug 10, 2006 | 10:23 AM
wicked_95z's Avatar
We you can do a temp fix like I did and shim your blower bracket but the proper way it to machine whatever you need to, more than likely the spacer
