Heads lifting under boost....
Old Mar 7, 2007 | 07:57 PM
Mekkadon's Avatar
well, it's been a while, but LS1SpeedInc said that their shop said that, the heads were OK. So hmm.........
Old Mar 7, 2007 | 08:56 PM
dlandsvZ28's Avatar
"The problem is that coolant is shooting out of the small overflow canister under boost."
It's doubtful - but if it can happen once, it can happen twice. Check your hose connections at the radiator cap.
An installer on my car flipped the hoses.
Steam vent hose into the overflow tank.
Overflow into the radiator.
The steam vent hose coolant had no where to go until the radiator cap would open - and after opening into the overflow tank. Never posed a problem in cool weather but sure did fast in hot weather and under boost.
Took me 2 hours staring at the engine bay trying to figure out what was wrong and then saw the mistake. That was one mistake by the installer - the other is too stupid to post.
BTW - I was not the installer.
Old Mar 7, 2007 | 09:06 PM
DeltaT's Avatar
Why the shop would decide they know better than ARP I'll never understand. It's not a case where more is better... Why not go to 200?
Jim
Old Mar 7, 2007 | 09:07 PM
99Z28LS1's Avatar
i've had my overflow blow out once on the dyno, it was scary but nothing too bad
ou812/z28's Avatar
tourqing the heads to 100lbs may distort the top of the block and be the cause of the coolant being pushed out under boost.just my 2 cents.
Old Mar 8, 2007 | 11:56 AM
stevieturbo's Avatar
Why would it distort the top of the block ??
My only concern about 100lbft, would be the fact that the fasteners were never deesigned to be used under so much tension. They may in fact clamp less under such circumstances.
Old Mar 8, 2007 | 12:10 PM
kp's Avatar
kp
Lot of engines (he has an LT1 I presume) have the head bolts threaded pretty much right into the deck and they arent blind but LS1 head bolt holes are not really a part of the deck so much.
but unless you have 1/2" or L19 studs 100ftlbs with moly is just going to stretch them out most likely..
Old Mar 8, 2007 | 12:22 PM
Wonder which would give first ?
Alu threads in block, or the stud ( stock sizes here ) ?
Old Mar 8, 2007 | 12:50 PM
kp's Avatar
kp
Lot of threads in the block, the stud will pull apart right where the course thread meets the shank at the (point of smallest diameter out of the threads) most likely. Now if you were threading a bolt in @ 100ft lbs the threads might tear out first.
Old Mar 8, 2007 | 01:13 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Cough....backpressure, cough cough . Have you checked it yet at 15psi?? Make sure the gate is shut??. Most of the LS1's I have dealt with that are turbo that have heads lifting is due to the tune , which appears you have that right, or its the backpressure created by either the turbine sizing, leaky gate, or leaky BOV. If either one leaks, you have to run a higher turbine speed to achieve boost and or create more exhaust pressure to overcome the WG.
Old Mar 8, 2007 | 02:17 PM
Mekkadon's Avatar
sorry if I gave the wrong impression....
It's not pushing coolant anymore, it's at 9PSI now on pump.
But @ 15PSI and race gas and LS1SpeedInc's tune, the car makes 660RWHP, about 110RWHP more than the previous 15PSI tune that was on the car. Kinda shows you that tuning can make a difference.
I haven't ran it @15PSI yet....I'll keep you guys posted.
Old Mar 8, 2007 | 08:09 PM
  #32
eb02z06's Avatar
Anyone try those new gaskets from Cometic? Those Phuzion gaskets? There supposed to seal even in the event the head lifts?
