Rotating Assembly For Turbo car
Old Aug 11, 2006 | 06:51 AM
02SSLE's Avatar
Default Rotating Assembly For Turbo car
hey guys as most of you know my engine is down. Anyway I was told that eagle H beam rods with L19 bolts aren't strong enough for what I am doing. The new setup I am looking to put down around 700 rwh and more in tq. Do you guys think that 6.0 crank in iron block with rods above and weisco pistons are up to it? Would appreciate any feed back. TKS
Old Aug 11, 2006 | 08:41 AM
cablebandit's Avatar
i dunno what you are doing but I had ross pistons on stock 5.7 rods/crank for awhile and i cracked the block...rods were still good. that combo dyno'd 703/775
Old Aug 11, 2006 | 04:57 PM
Ari G's Avatar
www.gofaststuff.com think they have a assembly with L19 that will take 1300-1500
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1
www.cncmotorsports.com
Old Aug 11, 2006 | 05:02 PM
Zombie's Avatar
I'm running some $275 eagle i-beam SBC rods, used diamond pistons and a stock crank.
My stock motor held up for quite some time at the 600+ rwhp, rod bolt stretch and valve float got me in the end though. Motor developed a slight tick from rod knock.
Old Aug 11, 2006 | 05:46 PM
KHShapiro's Avatar
What kind of compression do you want to run? What size Turbo? What kind of Weisco pistons? Which Eagle rods?
If the pistons are a No2 or FI piston then they are fine, If the Rods are LS1 Specific then they are fine and the L19's arent a problem either. Block and Crack, again fine.
Old Aug 11, 2006 | 06:06 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
<----Eagle rods
Old Aug 11, 2006 | 06:48 PM
orange88's Avatar
<-- carillos
Old Aug 11, 2006 | 08:10 PM
stang90gt50's Avatar
Ive dynoed a few turbo mustangs running standard $350 Eagle H-beam rods /w ARP 2000 bolts making over 1000rwhp....with L19's 1200rwhp would be no issue
Old Aug 11, 2006 | 08:59 PM
ddnspider's Avatar
Eagle crank
Callies rods
Weiseco pistons
Old Aug 11, 2006 | 09:03 PM
ABeasst's Avatar
lunati pro-mods
lunati crank
diamond pistons
Old Aug 11, 2006 | 09:59 PM
BIG BAD BLACKSS's Avatar
Speed inc made 995 RWHP and ran a 8.95 on eagle H-Beam rods, they say they had the regular ARP bolts even, not ARP2000/L19.
Old Aug 11, 2006 | 10:49 PM
B18B1LS1's Avatar
If you have a good tune in the car those rods should be fine for what you want. It's when things go wrong that those high dollar pieces start to shine. There are a few stock bottom end cars getting right around those numbers on a good tune already.
Old Aug 11, 2006 | 10:55 PM
NA$TY-TA's Avatar
Thats exactly what im running......
9.2@150.... @3500lb race weight that over 900rwhp........ it can take it........ stock crank also....
Old Aug 11, 2006 | 11:02 PM
02SSLE's Avatar
today I decided to order me a 6.0 iron block from GM. I am putting together a 402. Also I am sending my 241 heads to Brian at TEA. He is going to cnc them new valves and make my heads 72 cc chambers said it would work really well for me. What do you all think?
Old Aug 12, 2006 | 08:35 AM
NA$TY-TA's Avatar
That sounds like a good plan..... just be ready to go with a bigger turbo when you really plan to push the setup because that 76mm turbo is going to be to small..... i know i was there.....
We tried with my GT42-76 on my 370 and it was done by about 14-15 psi... 200+ degree intake temps..... so just keep an eye out.
Will a 88 fit that kit u have now???
Who do u have in mind to build the motor??
Kyle
Old Aug 12, 2006 | 09:13 AM
02SSLE's Avatar
76 took some modifying to fit so don't know if 88 will. I was running and holding 18 pounds with 347 so I don't know. One of my good friends is building it. He builds motors and race cars. This is not a race car. This is my every day driver.
Old Aug 12, 2006 | 09:14 AM
02SSLE's Avatar
what do you think about my Heads going to TEA for treatment?
Old Aug 12, 2006 | 10:40 AM
B18B1LS1's Avatar
TEA does great work. You won't be disappointed I'm sure!
Old Aug 12, 2006 | 03:38 PM
NA$TY-TA's Avatar
I hear it holding 18psi on 347 but the difference in flow with a 370ci motor and a 402-8ci motor is a huge difference for a 76mm turbo.
Just be careful and moniter your air temps when you up the boost.
Kyle
Old Aug 12, 2006 | 03:59 PM
02SSLE's Avatar
only wanting to run 12 to 15 psi with this setup. Should put down around 700hp and little more tq.
