bigger radiator
Old Aug 13, 2006 | 11:10 AM
STALL UP's Avatar
Default bigger radiator
has any one used the SLP or the BE-COOL bigger radiator? If so how do they work and which one is the best. for an 02 Z28
Old Aug 13, 2006 | 03:33 PM
Darren P's Avatar
also interested in this question
Old Aug 13, 2006 | 05:15 PM
koji777's Avatar
dont run a radiator at all.... too heavy.... just drive it when its cold outside and pack alot of ice on your intake
j/k I'm curious myself.....
Old Aug 13, 2006 | 08:22 PM
618HAWK's Avatar
Installed the SLP unit. Happy with the out come. Direct rplacment. Have a buddy that has the BeCool works just as good. Did take up a bit more room, when it came to his inlet hat for the blower.
Old Aug 13, 2006 | 08:34 PM
bboyferal's Avatar
Stock radiator has always been good to me in traffic with the AC on...
Old Aug 13, 2006 | 08:37 PM
ozws6's Avatar
With my low comp 402 the stock radiator wasn't keeping up to my liking even with a 160 thermostat and lower fan settings. I purchased a used LT1 radiator (93-96). The SLP rad is nothing more than an LT1 radiator with the lower heater core hose and coolant level sensor ports blocked off. I saw a good improvment with the LT1 rad in 100+ temps. I do plan to upgrade to a BeCool or other radiator that is two core next spring after I install a turbo for added cooling capacity.
Old Aug 13, 2006 | 08:43 PM
CTSmechanic's Avatar
Dont forget about Griffin or Fluidyne radiators there less expensive than a Be Cool and work very well. Or Cal Sonic's if you have tons of money
Old Aug 14, 2006 | 12:49 PM
DarkFormula's Avatar
I've just recently installed an OEM LT1 radiator scored brand new from Ebay for $97 shipped. I've seen a 15* drop on operating temps while driving around and 10* in traffic.
The radiator also came with the block off kit for the heater core provision used on the LT1. Everything else, including the low coolant sensor placement, is identical.
 Michael S. Palmer
Old Aug 17, 2006 | 05:47 AM
JIMMYZZ28's Avatar
If you can afford the space you can get a universal fit radiator like Griffin 25272 radiator which is 2row 1.00". Everyone has a version like this wether it is be cool, fluidyne or afco. All the universal fit items are basically the same 15 fpi and close to the same in pirce. Best bet is to check for availability. Griffin also has a single row 1.50" rad that is a little more then the LT1 or SLP rad and uses 18fpi. Since the new owners have stepped in we are no further out then three weeks.
Old Aug 17, 2006 | 07:46 AM
WAHUSKER's Avatar
The SLP radiator is an LT1 radiator. I had one for 6 months & it started leaking water to the ground AND the tranny cooler! SLP said too bad, buy another one. So I dumped it & bought a Be-Cool. FAR superior product!!! Basically the same unit as an LG, only with a tranny cooler instead of an oil cooler.
And my blown stroker motor runs as cool as my cammed stock motor used to. It does have a clearance issue tho, since it's a full 2" dbl core unit. I had to remove the AC conndensor & move the bottom forward to clear the s/c inlet hat. Well worth it IMO!
Old Aug 17, 2006 | 07:53 AM
Tiago's Avatar
anybody have a link to the becool rad?
Old Aug 17, 2006 | 09:05 AM
STALL UP's Avatar
so which radiator would be the best one for a direct replacement, Because I am getting pretty tight on room there not much to spare.
Old Sep 3, 2006 | 05:51 PM
Black Plague's Avatar
So the fluidyne for the LT1 will fit just as the stock LT1 unit would for a 02'?
Old Sep 29, 2006 | 06:31 PM
Word the LT1 Fluidyne radiator will fit! I talked to fluidyne and just as stated above just the heater core block off needs to be done. BTW this is a awesome quality radiator.
