guys with iron block and procharger in Fbody
Old Aug 15, 2006 | 11:18 AM
ty_ty13's Avatar
7 Second Club
Default guys with iron block and procharger in Fbody
are you guys just using the 2 holes on the front of the block and the one on the driver side to mount the alternator?
is this causing a problem for the procharger that goes on top of it?
are you guys having any issues supporting the procharger?
let me know what you guys are doing/ have done.
Thanks
Tyler
Old Aug 15, 2006 | 11:38 AM
koji777's Avatar
Tap the block( it will be obvious where) and call it a donr deal... with a 15psi pulley combo.. dunno the exact measurements, I have ZERO belt slip
Old Aug 15, 2006 | 12:32 PM
Blown408's Avatar
I also drilled and tapped a new hole.
Old Aug 15, 2006 | 12:53 PM
ty_ty13's Avatar
7 Second Club
is it litteraly on the side of the block... i think it came already tapped on my motor from LME but i just wanted to check...
its the raised rectangle on the side of the block on the drivers side?
im just glad theres no issues.
Old Aug 15, 2006 | 01:05 PM
WAHUSKER's Avatar
I have a picture of it in my Stroker album on my website. The hole you have to create is in the upper right hand part of the picture. Maybe this link will work, if not use the link in my sig & open the album.
http://community.webshots.com/photo/...43096065dfHdCc
Old Aug 15, 2006 | 01:14 PM
ty_ty13's Avatar
7 Second Club
great... thats the place i thought you guys were talking about... it was already tapped luckily
Thanks alot guys
