Sts Owners Help
Old Aug 18, 2006 | 02:48 PM
spare tire's Avatar
where are you at in SD? Close to sioux falls? If so why not go to excessive auto?
Old Aug 18, 2006 | 02:49 PM
2k1ws6's Avatar
what is afr supposed to be at idle
Old Aug 18, 2006 | 02:50 PM
2k1ws6's Avatar
About 80 miles from sioux falls. Is excessive auto good with sts kits.
Old Aug 18, 2006 | 02:52 PM
boostedtransam's Avatar
I sent you a message...
Old Aug 18, 2006 | 03:02 PM
spare tire's Avatar
I was curious if they fabbed a plate to seal the charge pipe since they did not install a BOV. Just trace the charge pipe down from the intake down to the 90deg elbow the BOV should be right around there. If there is nothing there. Than that would explain the low #'s and slow spool.
smoke20's Avatar
at idle you should see 14.0-15.0 it will fluctuate, at wot you should see no more than 11.5 afr anything above that and your tearing up your engine.
Old Aug 18, 2006 | 03:05 PM
message returned
Old Aug 18, 2006 | 03:08 PM
spare tire's Avatar
Yes from what I heard excessive is a good tuner for ls1's if you dont mind about a 2-2 1/2 hr drive I would say go to Dynosport. But excessive is a good tuner as well. Not sure if they have done any sts kits.
Old Aug 18, 2006 | 04:30 PM
2k1ws6's Avatar
There is no bov. I am not sure were the plate is supposed to be. Do you have a pic
Old Aug 18, 2006 | 04:35 PM
2k1ws6's Avatar
Is there different piping for a m6 and an a4. I looked at pictures of installs and on the elbow there was a spot for the bov on mine its just a straight pipe.
Old Aug 18, 2006 | 04:40 PM
2k1ws6's Avatar
http://www.supermotors.net/vehicles/...s/sts-a1-1.php
scroll down and in there install there is a little piece of pipe for the bov
Old Aug 18, 2006 | 05:50 PM
  #32
JD_Z28's Avatar
Sent you a pm.
Old Aug 18, 2006 | 06:50 PM
  #33
GXPPOWER's Avatar
14.5afr? wow. my car though not turbo or anyhting with headers/intake/exhaust before any tuning was running about 13.3 AFR on its own.
