Making my own crossover - questions on WG and flex section
Also, would it be wise to put a stainless flex section in the crossover to account for some expansion of parts and dampen vibrations? I know TTi did not put a flex section in their crossovers at first, but then the put a clamped joint in the later ones.
Now I got some flex joints in that had steelbraided on the outside and on the inside. I sent those back, was worried about the braid coming loose and ending up in the turbo.
The new one just has it on the outside.
The gate what ever is easiest seeing how you are no running a muffler noice will not matter.
Just aim it down and away.Ricky
Ricky, where did you get the flex pipe from? I would like to get a piece without braid on the ID also.
Thanks for the input guys. Pete.
Ordered a flex section and the pipes needed to do the crossover. I will be putting up some pics of this stuff in my thread.
Another question, where is the O2 sensor go in the crossover?
