Instructions on godzilla BOV
Old Aug 23, 2006 | 08:42 PM
bowtieman81's Avatar
Default Instructions on godzilla BOV
Anybody have instructions on a godzilla BOV? Don't have any on mine and want to know how to hook it up and set it. Thanks.
Old Aug 23, 2006 | 09:34 PM
MECHAM's Avatar
mine only has vacuum going to the top port and nothing for the bottom port except a fitting and a couple of inches of hose to atmosphere
http://flowerstechnology.net/images/mechamvac.jpg
Old Aug 23, 2006 | 09:57 PM
socalstreetracer's Avatar
is there any video on how the godzille bov sounds?
Old Aug 23, 2006 | 10:11 PM
So the bottom port is just a vent?
How is it adjusted, and are there any springs to change out (like a wastegate)?
Old Aug 23, 2006 | 11:25 PM
MECHAM's Avatar
there are springs...but i havent adjust or messed with anything on the BOV
Old Aug 24, 2006 | 07:28 AM
What boost pressure are you running Mecham?
Old Aug 24, 2006 | 11:49 AM
MECHAM's Avatar
up to 13psi - limited by me and my lack up fuel pressure before..but that is all good now so up, up, up, up, up!
Old Aug 24, 2006 | 12:08 PM
I found this for the raptor BOV. I will guess the godzilla is the same, so I will hook it up and see what happens.
http://www.turboneticsinc.com/downlo...ypassValve.pdf
Old Aug 24, 2006 | 12:33 PM
MIGHTYMOUSE's Avatar
i have both ports hooked up
one for presence of intake vacuum to suck it open, the other for excess boost pressure to blow it open. i think its a great piece.
set the screw so that it is just sealed at idle.
Old Aug 24, 2006 | 12:36 PM
Thanks MM
Is there any way to make sure it is not bleeding off boost during operation?
Old Aug 24, 2006 | 01:27 PM
feel with your hand in front of it while you flip the throttlebody
Old Aug 24, 2006 | 01:29 PM
SUPER DAVES Z's Avatar
Originally Posted by bowtieman81
Thanks MM
Yep, set it up exactly like MM stated and it will not leak.
Old Aug 24, 2006 | 03:57 PM
MECHAM's Avatar
so...is the way i have it hooked up ok?
Old Aug 24, 2006 | 09:01 PM
mecham, that obviously will get the job done, but hooking the other port up to a pressure source between the turbo and throttlebody will make it respond quicker
Old Aug 30, 2006 | 11:05 PM
MECHAM's Avatar
hmmm.....interesting
i hooked my bov with top port vac and bottom port boost. and it sounds different from a wot run. everything else seems the same...
car doesnt hold requested boost to redline...nothing new there..
i was hoping this might of solved something....o well...at least it sounds different. ie..i can hear the bov more from a wot run.
Old Sep 1, 2006 | 07:36 AM
u dont think changing this maybe had an influence on the dyno do you? maybe the lines backward?
Old Oct 10, 2025 | 12:56 PM
priobe's Avatar
I know this is an old thread but I came across this thread while searching for information regarding the Tubonetics BOV Godzilla.
I am hoping someone can help
I have part #10656 that does not have the adjustment screw and see there is 10765 that does have an adjustment screw.. If I tap threads and add a port for vacuum on the top and install a bolt would this be the same as 10765 or is there something different?
Also can someone provide a diagram as to where the vacuum hoses need to get hooked up. At idle my car is running rick with the top vacuum connected to intake behind the throttle plate and the bottom port connect at the compressor of the turbo.
As soon as I disconnect the top port and cap the intake car runs perfect. My valve does not have an adjustment screw so not sure if this adjust will solve my problem.
I know this thread is over 20 years old but hoping someone can help "Hail Mary Pass"
Old Oct 10, 2025 | 12:59 PM
Black_Sunshine_99's Avatar
Did you try reaching out to Turbosmart?
