how do you run oil lines?
Old Aug 26, 2006 | 05:08 AM
X_Spearmint's Avatar
Default how do you run oil lines?
I'm getting ready to install twin turbos on my T/A. I'll be having some help from a welder on the piping, but as for the oil lines that's all up to me. I've never run oil lines for a turbo and haven't a clue. Can anyone help me out? I'm trying to have them in the car by next week and at the track the following.
Old Aug 26, 2006 | 08:09 AM
Country Boy's Avatar
Senior Member
tap an oil source from above the filter so the turbos get filtered oil and return it to the pan above the oil line. Make sure youre drain is all downhill, otherwise youll have to run a pump.
Old Aug 26, 2006 | 12:08 PM
MiaSSmaro98's Avatar
yeah but what if u drain is not gravity feed then u need a pump and u can run it to ur fill cap exc
Old Aug 26, 2006 | 01:49 PM
Senior Member
Yeah, if you have a pump, you can run the drain anywhere.
Old Aug 26, 2006 | 02:16 PM
SINISTER's Avatar
im running a pump on mine and running it back into the pan just like country boys..
but useing -10 line that look slike -8
Old Aug 26, 2006 | 02:38 PM
Senior Member
nah, -4 supply with .060 restrictor and a -10 return.
Old Aug 26, 2006 | 04:57 PM
country boy were did u buy ur restrictor,how do u know if u need one?ive heard some turbos have built in ones.do u know if a master power t70 needs one?
Old Aug 26, 2006 | 06:36 PM
Senior Member
I got my Function7 piece from Ebay. It built in to the mounting plange to the turbo. Jose said to start at a .060 and work from there on my turbo. You could call Jose at FI and ask him about the MP turbos.
Old Aug 26, 2006 | 10:37 PM
alright i'll give him a call
Old Aug 27, 2006 | 07:37 AM
would I need to tap the oil pan twice for the twin setup or just use y fittings?
Old Aug 28, 2006 | 12:22 AM
anybody? I've never done a turbo setup myself. Also I need to make sure I have everything I need, so if someone could tell me what all the essential parts are that'd be really helpful aswell. I think I know, but I'm not sure.
Old Aug 28, 2006 | 12:48 AM
red90cobra's Avatar
i would just tap one on each side
Old Aug 28, 2006 | 01:05 AM
I just feel like I'm missing something. I have my oil lines, catch cans, k&n filters with drycharge wraps, a shop to do my piping, onboard computer running efilive to constantly monitor my system, bov, wastegates,methanol injection system,what am I missing?
Old Aug 28, 2006 | 03:13 AM
red90cobra's Avatar
you got gauges to monitor your boost? wideband? what's ur fuel system? you need injectors and a fuel pump.
Old Aug 28, 2006 | 06:31 PM
I already have fuel rails, injectors and an inline pump because I'm running a 200 shot right now. I'll be upgrading the injectors and maybe the pump for the turbos. I'm not using actual gauges. I have efilive always on monitoring my car and I watch the efilive dashboard which is essentially a digital gauge cluster.
Old Aug 29, 2006 | 11:07 AM
black_z's Avatar
I would invest in a fuel pressure gauge
Old Aug 29, 2006 | 01:56 PM
67Firebird455's Avatar
Hey Country boy, I'll vouch for the function 7 piece. Real nice looking piece, great craftsmanship and seems to work like a champ. I'm also running .060" restriction into my MP70.
