ls1 missing at high rpms help?
Old Aug 29, 2006 | 12:06 PM
redlinec's Avatar
Question ls1 missing at high rpms help?
i have a 98 ls1 with a 10 psi vortech system aftercooled and 42 # injecters. ok now this is whats going on any were above 3000 rpms it will start to cut out it will like change every time like 3500 or 4000? but if i keep the gas to the floor it will start missing and spitting. if feels like i loose the boost but my boost gauge stays up? any help?
Old Aug 29, 2006 | 12:26 PM
JMBLOWNWS6's Avatar
First off I would stop trying to go rev thru it. Your going to mess something up. Do you have a tune on the car or what vortech gave you? What is your fuel pressure? Do you have a wideband on the car? Have you checked the plugs? What kind of plug are you running? Need to post a little more bro for any of us to help you out
Old Aug 29, 2006 | 12:32 PM
redlinec's Avatar
i have a tune not sure if its right ive done it on ls1edit, i dont no fuel pressure lol no wideband no i have not checked the plugs i think ill start there probely..
Old Aug 29, 2006 | 12:33 PM
MavrikTA's Avatar
Ive been reading about valvefloat lately on boosted LS1's. Id venture to bet it is tired valvesprings.
Old Aug 29, 2006 | 12:34 PM
JMBLOWNWS6's Avatar
Let us know what they look like. Could also be a fueling problem.
Old Aug 29, 2006 | 12:44 PM
JD_Z28's Avatar
Check your plugs you might of fouled them. Look for oil on them.
Old Aug 29, 2006 | 05:32 PM
redlinec's Avatar
ok ill do that and let you know thanks eveyone for your help!
