look at this cam.....give input
Old Aug 31, 2006 | 06:19 PM
ou812/z28's Avatar
Default look at this cam.....give input
i am going with a .030 6.0 liter set up. weisco turbo pistons, scat rods, ported heads and victor jr efi intake,90mm accufab tb. 1 3/4 forward facing headers i made and a 74mm turbo from hose at forced induction. and a after cooler.
here is the cam specs.
hydrolic roller
intake at .050, 230
centerline112
valve lift.595
exhaust at .o50,226
centerline120
valve lift.573
lobe seperation 116.
Old Aug 31, 2006 | 07:31 PM
Bird-Of-Prey's Avatar
I too would like to know what others have to say. I've asked in many different posts about turbo cams and it seems that no one really has a handle on them. They either preach reverse splits, or say reverse splits are over rated and only needed in a restricted exhaust setup. Lsa seems to vary also. I even changed my cam of choice from a 224/228 @ 114 to a 227/224 .569/.563 114 LSA only because I had more input for the reverse splits. It definatley comes down to the entire setup but then again no one was really any help there either. I say every cam is a turbo cam. Some will work better than other's and good luck figuring out which one that will be.
Old Aug 31, 2006 | 07:49 PM
ninetres's Avatar
In about 2-4 weeks I will have results of my 228-232 588/595 @114+2 xer lobe cam with a t76gts running on a tial 44mm WG w/ a 0.6 bar spring.
My buddy has a similar turbo build with GREAT results with his reverse split cam. It is much smaller in duration and lift than yours though.
Old Aug 31, 2006 | 09:28 PM
engineermike's Avatar
hydrolic roller
intake at .050, 230
centerline112
valve lift.595
exhaust at .o50,226
centerline120
valve lift.573
Who spec'd that out? I know that INTMD8 had one similar and it went in the trash cam. I think his was 227/218-117. He said it was soggy down low and didn't do very well up top. He later switched to a 224/224-113 and gained low-end response plus significant horsepower.
Mike
Old Aug 31, 2006 | 10:36 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Sounds nice Benjamin. My cam is a 236 single pattern cam. Has a lot more overlap than 116.
Old Sep 1, 2006 | 12:27 AM
67Firebird455's Avatar
Sounds like an excellent cam to be honest with you, I'm honestly a fan of reverse split cams on turbo applications, call me old school! =)
Old Sep 1, 2006 | 05:11 PM
ou812/z28's Avatar
Mike
the cam was part of the deal in a trade i made. so i am going to run it and go from there. it may make a ton of power and then it may not.it is a cam motion cam and it came from futralls shop here in walker...
