Tee'ing off the brake booster line?
Old Sep 1, 2006 | 10:45 AM
Country Boy's Avatar
Senior Member
Default Tee'ing off the brake booster line?
What are yall using to tee the booster line? I have looked EVERYWHERE and cant find a 1/2" T fitting. I need a 1/2 x 1/2 x 1/4. Hell, I cant even find a 1/2 T.
Old Sep 1, 2006 | 11:15 AM
shiftinda93z's Avatar
went to TSC (tractor supply company) and got a 1/2 T ( has 1/2, 1/2, 3/8 but they had 1/2,1/2,1/2 in stock too). I then had to get 3/8 down to 1/4 for the bypass.
Old Sep 1, 2006 | 11:49 AM
smokinHawk's Avatar
you could use a brass T with the appropriate sized barbs, they have them at all hardware type stores.
bowtieman81's Avatar
Carl, I was in the same boat. Could not find a 1/2" T.
I actually was able to use the port on the intake where the factory PCV goes. If you want I can shoot you a pic.
I was also a little hesitant to cut my booster line for safety reasons.
Old Sep 1, 2006 | 11:59 AM
Senior Member
I looked at that, but it ends up being huge and ugly. I thought about using the PCV port, but I still need to Tee down to 1/4"
Old Sep 1, 2006 | 12:02 PM
The pcv port uses a 3/8" hose, and I found quite a few different T options at the local NAPA store for 3/8" hose. I got some T fittings that worked out real good for what I needed. Just a thought.
Old Sep 1, 2006 | 12:06 PM
Senior Member
I was going to use the PCV for a vacuum source undle idle or light throttle while using the inlet to the turbo as the main vacuum source. May change up some. I didnt think a 1/2" T was this hard to find..
Old Sep 1, 2006 | 12:14 PM
I think I got confused. I thought you wanted to T the booster line for your gauges. What are you trying to do exactly?
FWIW, I was able to run my boost gauge, BOV, and PCV off that single port on the intake.
Old Sep 1, 2006 | 12:19 PM
Senior Member
Thats what I need the T for... guage, BOV and wastegate. I was going to use the PCV port as a secondary vaccum source at idle.
Old Sep 1, 2006 | 12:26 PM
Here is what I did Carl. It works and I have no had any problems with it. I may eventually get rid of EVAP system and use that port, or drill one in the intake. But this gets it done for now.
Old Sep 1, 2006 | 12:30 PM
Senior Member
interesting.. that could work....
Old Sep 1, 2006 | 12:45 PM
SINISTER's Avatar
ok talk to me goose im freaking brain dead today..
im looking at this and my eyes are going buggie lost on the fuel filter?? and CV???
what goes to the waste gate?
lets talk catch can first..so go from my ls6 valley tray to the the catch can, and then the nipple on my turbo connect that to my catch can?
im going to go get coffee and come back and look at this..
i dont think i have any of that crap..
what line would i want gopi9ng to my FPR
Old Sep 1, 2006 | 12:50 PM
OK, for the brain dead today
CV = check valve
The fuel filter is just that, I got a clear plastic fuel filter from NAPA (3/8" nipples) to use as an oil seperator. It keeps from sucking the oil into the intake manifold when not in boost. The check valve is there so that during boost you don't pressurize the crankcase.
My check valve is just a generic PCV valve, again from NAPA. Just be careful, some PCV valve have a pin hole so that they don't completely seal up. You want one without the pin hole.
Your wastegate signal come from the port on the compressor housing. I think that is the same for all turbo systems.
And yes, you have it right
LS6 valley cover -> catch can -> turbo inlet
At present I have no FPR, so not an issue. That is why I may end up changing things later down the road.
Old Sep 1, 2006 | 12:54 PM
How do you like my art skills Carl? I can go head to head with your paint skills now
Old Sep 1, 2006 | 01:12 PM
SINISTER's Avatar
ok cool
what about dis set up from mighty
https://ls1tech.com/forums/showthrea...=break+booster
Old Sep 1, 2006 | 01:17 PM
His is very similar to mine, he is the one who coached me on mine
Old Sep 1, 2006 | 01:31 PM
SINISTER's Avatar
ok so what his is and your same thing hes is just tucked back in more..and going off the brerak booster
Old Sep 1, 2006 | 08:42 PM
Senior Member
You arent diss'in my paint skillz, are ya
I would run the wastegate off of the intake reference. That will give you a better reference and a true boost reading since you drop pressure running through an IC or such.
Old Sep 1, 2006 | 09:17 PM
Hmm, you are right about the pressure drop. Why do the instructions say to use the compressor port? That might explain why I am seeing 5 psi on a 7 psi spring.
Old Sep 2, 2006 | 12:33 AM
StoleIt's Avatar
NKAWTG...N
I just stuck a small barb right in that honker of a hose and then smudged some RTV around it.
