new best track time!!!
So can rick at synergy....he did the speed density tune. He said even if Tony upped it he would go wayyyy slower because anything above the set psi he dumps fuel and pulls timing in case something goes wrong and it boosts real high.
I'm sure Tony will take you for a ride and you can peep his boost guage and boost controller.620-640 though a th400 and 9"
KABOOM The Best V8 Stories One Small Block at Time
Im done
o yea nice t brake a studder box launches tony looked good.
I've had cars make 10 psi on the dyno and immediately make 12-14 on the street soon as they come off with no changes....theres no dyno at the track so no reason to criticize as we all know Tony doesnt know much about cars or lugnuts.
Btw: It DOES take 600-620 rwhp in that car @ 3600 lbs to run 129 mph... so regardless of if you dyno 300 rwhp or 550 rwhp, the car made 600 rwhp at least to run that speed. You will be buying a shortblock in the next couple months, have fun with it till then.
still going strong! by the way i went 126 doing an 11.6 with my 6 speed 4 months ago was i on 12 pounds then ???????NO!! i gained 2 mile per hour with the th400! do the math thanks good by ....and if you really want to know call rick at synergy your self....we got the meth working and turned up my timming!! remember i was only on 12 degress of timeing ! now im on 16* 4 degress on a turbo car is a huge differnence! and its 128 not 129 also 3500 not 3600 case closed tony for the win
Im done
http://www.race-cars.net/calculators/et_calculator.html
It says my car should have 389whp
My car probably makes 330---350whp. All it had was a lid and headers
Do you think I have 390 whp?????? NO.Go hp to trap speed debate!!!!!!
those calculators are a guest-a-met calculation doesnt mean there correct!
Rear Wheel Horsepower
Input the Weight and 1/4 mile Trap speed of your vehicle.
Our Calculator will generate its rear wheel horsepower.
Vehicle Weight
In Pounds
3500
1/4 Mile
Trap Speed
in MPH
128
Your Rear Wheel
Horsepower
is: 572.86
make sence to me!
)Dyno's don't tell the story at all with a th400. I've never weighed the car but it hasn't gotten lighter since it was stock so I'm guessing 3800 give or take 50 with me in it, th400, 9", iron block, etc. Doing the simple HP calculation that give me 595 rwhp based on my weight and trap speed.
For as horrible as the time sounds for the amount of boost, everyone runs slow in this weather. T76 stock motor 15psi, 11.1 @ 124, 383 LT1 14psi D1SC 11.0 @ 127. Come on cooler weather!
I'm jealous of you tony, I want my 130mph trap so bad (and my 10 sec pass).
No corvette parts. 241 casting LS1 heads, 6.0l truck cam that came stock in 2001 ls1s. LS1 block.
Do you think headers and a lid made my car gain 90 whp (like your calculators suggest)? Weird.
BTW--Tonys cam set-up made ~370whp. Truth.
Wait wait..... the 6 spd carries a spool time for EVERY GEAR... on the auto it's spool once out of the hole and stay spooled the whole trip; that HAS to be worth something.
