Scavenger pump options
Old Sep 15, 2006 | 01:49 PM
WestSide's Avatar
Originally Posted by NTSOS
Can you hear it running at engine idle?
Thanks!
John
Nope. It has a plate on the backside of the pump with 4 rubber mounts, so that no vibration noise will be heard once secured properly.
Old Sep 16, 2006 | 08:57 AM
MiaSSmaro98's Avatar
ahh that one doesnt have for a -10 line?whats the purpose of the reservior
Old Sep 18, 2006 | 07:11 AM
chuntington101's Avatar
would these pumps work for a custom rear mount to?? i cant see why not.
thanks Chris.
Old Sep 18, 2006 | 07:54 AM
SINISTER's Avatar
thanks Chris.
yeah they work
Old Sep 18, 2006 | 07:57 AM
SINISTER's Avatar
the purpose of the reservior is to allow the oil to collect and sit then be pulled..
we tried on my set up just runningthe lines directly to the turbo but it smoaked...when oil is moved to quickly it tends to foam..
the resivor on my car was made a bit larger then others mines 2x4 in the shape like an l so its like a sump.
and its vented
Old Sep 18, 2006 | 08:59 AM
Inspector12's Avatar
TT-TECH Veteran
Originally Posted by WestSide
yes, but im using 3/8" ID hose between the res and pump, and from the pump to valve cover
I have always been told to not use anything smaller than a -8 on the drain lines. I guess your resivor is doing ok for you.
Old Sep 18, 2006 | 12:49 PM
FUroundeye's Avatar
He has a -10 an between the turbo and reservoir, which is where it matters. From the reservoir back it's not nearly as critical b/c the pump is sucking it out, as opposed to the traditional gravity drain style.
Old Sep 18, 2006 | 06:06 PM
JAvenger007's Avatar
what does 3/8 translate to? -8an? I was thinking about downsizing mine to 3/8 because of how the pump is setup and the fact that I already had 3/8 fitting coming off the turbo.
Old Sep 18, 2006 | 07:38 PM
FUroundeye's Avatar
3/8 is -6 an
Old Sep 18, 2006 | 08:08 PM
mcx's Avatar
mcx
I run 3/8"pressure hose out of the turbo into a Mocal pump and 3/8" hose back to the valve cover...no smoking ever..i dont use a line restrictor or a one way valve..the Mocal was noisy at first but now its not even noticable[remounted].
Old Sep 18, 2006 | 10:19 PM
Mike 01WS6's Avatar
Originally Posted by FUroundeye
So the Mocal and Tilton units are one in the same, just w/ different brand names?
Yes, exact same pump. Different labels. Rebuild kits fit both.
Old Sep 18, 2006 | 11:02 PM
  #32
Sounds good. Ill just leave mine.
FUroundeye i'd order a tilton off summit for the free shipping. They should be available. And considering theyre the same design as the mocals you should have long pump life.
Old Sep 18, 2006 | 11:23 PM
  #33
Mr_president's Avatar
anyone have pics of where they mounted there pumps??
