Manifold kits
Old Sep 14, 2006 | 11:44 AM
1998TA__1991RS's Avatar
Default Manifold kits
is it possible to use ZO6 manifolds on a f-body turned backwards to mount the turbo to? We have a set laying around. and i can get a good deal on a precision pt76 and hot side tubing. btw the car doent have AC or ABS anymore so that will free up alot of room, thanks guys
Old Sep 14, 2006 | 02:11 PM
DSG's Avatar
DSG
No the 5.3/6.0L truck manifolds are the only option if you plan to go that route. Great sticky at the top of the FI forum....
Old Nov 9, 2006 | 12:02 AM
HotRodKid's Avatar
the reason people use the truck manifolds is because they exit out the rear on each side (which becomes teh front when used for the turbo setups)
on the ls1 and zo6, one manifold has the dump somewhat towards the back, but the other manifold dumps in the middle, and once you flip the middle dump mani to the other side, the flange hits the motor mount on that side
Old Nov 9, 2006 | 07:16 AM
smokinHawk's Avatar
the vette motor mounts are different then the fbodys, the vette manafolds i think interfer with the fbody steering shaft and motor mounts.
