Injector questions
Old Sep 15, 2006 | 04:23 PM
Funkybird's Avatar
Default Injector questions
With my current setup i'm making 400rwhp with about 4-5psi and i'm going to run 12-15psi here shortly with my P1SC. Do you guys think my 42lb injectors will be able to handle this, and will i be safe to run on pump gas (91)?
Old Sep 15, 2006 | 04:35 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
15 PSI on 42s? No way! What numbers are you after?
Old Sep 15, 2006 | 10:02 PM
NOSjohn's Avatar
Restricted User
Each injector supports roughly 77hp. So, depending on where you want to be, do the math, then divide by 20% to get your rough wheel HP level.
Hint: they will support ~493rwhp.
Old Sep 16, 2006 | 09:29 AM
bowtieman81's Avatar
Agreed, I have 42 lb injectors now and I see about 85-88% duty cycle at only 7 psi.
Old Sep 16, 2006 | 10:11 AM
Funkybird's Avatar
I don't really have a power goal, but I have already recieved my new pullies from exotic performance plus and I told them I wanted to be between 12-15psi. and this winter i'm going to upgrade to a D1SC and that will be it for me as far as performance goes. What kind of gains do you guys think I should expect to get from this pully swap? Oh and btw I have an auto with a 3000 stall.
