Larger Air Filter for procharger setup
Mike
No way that bitch is fitting in where the stock accordion/filter goes.
Anyone need one, slightly dented ?
Maybe I'll try the RU-1785 that Boone mentioned.
Also, what part number are you guys using for the little breather filter on the inlet hat ? Think this one would work ? RU-0800 Shape: Round straight
Length (in): 4.000 in.
Inlet Flange Inside Diameter (in): 2.438 in.
Top Diameter (in): 3.500 in.
Bottom Diameter (in): 3.500 in.
Rob (Bad30th)
PS you should include the little K&N filter for the bypass valve in your kit too, since most people still run the stock config.
Not a bad idea on including the K&N for the bypass valve, although we have had a lot of people tell us they are running a larger race style bypass, and they would just weld on a larger flange. What we need to do is to have a list of options available. Thanks! Bob
Looks pimp and I have heard nothing but great things about them.
