T76 to T88 spool difference with an auto?
Old Sep 24, 2006 | 12:21 PM
NA$TY-TA's Avatar
Originally Posted by Zombie
I am trying to max out this turbo but am running into issues getting it to go over 17psi consistantly. I have been able to hit 20psi in 3rd gear once, but I didn't feel any difference and my IATs went up. Does anyone know roughly the max boost for a T76 on a 370 cube motor?
My turbo also uses the Innovative R wheel which has a trim of 1.00 and Jose tells me it's quite heavy. I'm at a big disadvantage with having the turbo all the way at the back, but I'm trying to make up some of that difference by insulating my exhaust. I am either going to wrap it or just get it ceramic coated and be done with it. Luckily we have a coater here in town.
JZ 97 SS 1500, since you are in here and know about my setup, do you think it would be a worth while switch to go to an 88mm based unit or would it be too much for my setup to spool. A friend of mine who likes to fabricate have been considering doing a variable a/r experiment with a divided housing so that is the other idea that I have... more plumbing LOL
I've been going against the grain a bit since starting this project (back in the days when a rear mounted turbo couldn't possibly make boost). I'm kinda curious as to how far I can take it now. My goal with this setup is mid 10's and a 130mph trap speed. I should be getting really close to that next week. The car is an absolute blast to drive, especially from a highway roll with my gears.
I could always start spraying it I guess, that guarantees the same drivability and fun factor it is now.
Zombie,
T4 flange correct....... with my 370 and my GT42-76mm turbo on a T6 flange i was maxed out at like 14-15 psi and my intake temps were over 200+ degree's...... back pressure was huge....
Swapped to the S88 and picked up 9mph at the same boost level at the track.........intake temps dropped dramatically..
Kyle
Old Sep 24, 2006 | 12:28 PM
NOSjohn's Avatar
Restricted User
A 370c.i. motor has a demand/flow of about 90lb./min. of air at 6,500 RPM at 20lbs. of boost. The standard T-series of a 76 has a max. capacity of about 93lbs./min. I believe max boost on a standard 76 is around 32lbs. At that point though it is roughly only 65% efficient.
