with stock motor and setup,..What would the differnce be going from d1sc to a p1sc
Old Oct 5, 2006 | 03:38 PM
2000FormulaMan's Avatar
Default with stock motor and setup,..What would the differnce be going from d1sc to a p1sc
I was wondering if there would be a large difference going from a D1 to a P1.
If I have a stock motor,...8 rib set-up D1, both at 10psi boost.....and I switch the head unit to a P1,...would there be a large noticable differance?
Would I lsoe alot of power? Does the D1 drive differntly from the P1.
Thanks!
Old Oct 5, 2006 | 04:28 PM
kp's Avatar
kp
You will lose a couple PSI with the same pulleys, On a stock engine you could probably pulley up the P1 to do the same safe HP as the D1. The P1 will boost up a little quicker in the mid range but you probably wouldnt even notice it..
Old Oct 5, 2006 | 05:18 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Going from D1 to P1 with same pulley will net you a loss of 2-3 psi less of boost.
Old Oct 6, 2006 | 12:52 PM
Okay,
So if I switch out the Pulley to get that boost back to 10psi......would there be much difference then?
Will I be losing much power?
Thanks
Old Oct 7, 2006 | 02:17 PM
Whitez406's Avatar
If u wanna trade that D1 for a low mileage P1 let me know
Old Oct 7, 2006 | 04:33 PM
eb02z06's Avatar
I went from a P1 to a D1 and went to a larger pulley even and picked up 40 rwhp and 50 rwhtq. The difference was night and day-the D1 just made more power and torque everywhere-I don't know why you would bother switching?
