What shortblock for a turbo project?
so figure otu how muchmoney u are willing to let go and go from there. GL man
John
Okay fellas if you need a block, here it is:
This is for a 408ci;
New 6.0 block, Eagle 4340 forged 4" crank, 6.125 Eagle rods with ARP rod bolts, Wiseco pistons 4.030 bore, Childs & Albert rings, Federal Mogal and Clevite bearings, ARP main studs.
LIne bored, cylinders bored and honed, rotating assembly balanced, decks checked, file fit rings, and assembled. This also includes drilling and tapping the hole needed to bolt up the accessory bracket.
$3600.00 no core required.
Lead time is 2-3 weeks. Lunati crank available. Depending on your heads, JE or Diamond pistons may be substituted for the Wiseco.
