oil everywhere!!!!!!!!!!!!!!!!!!!!!!!!!
Old Oct 16, 2006 | 10:17 AM
todd4168's Avatar
Default oil everywhere!!!!!!!!!!!!!!!!!!!!!!!!!
Out riding around and got on it hard and blew the valve cover gasket out, it was horrible. very sad day. It seems i cant win for losing.
Old Oct 16, 2006 | 11:41 AM
Mike 01WS6's Avatar
I had the same thing happen....you're probably pressurizing the crank case. I lost a cylinder and as a result blew the valve cover gasket.
Old Oct 16, 2006 | 11:53 AM
LS2Camaro's Avatar
Thats bad news man, sorry to hear that. I guess its time to pull it out and build it better eh?
Old Oct 16, 2006 | 12:40 PM
vanillagorilla's Avatar
Do you have a breather anywhere on the engine? Any kind of catch can or something? I can't believe that it would blow the valve cover gasket before it would blow the dip stick out. It think you should look into a crankcase evac kit from moroso or mr. gasket.
Old Oct 16, 2006 | 08:13 PM
nvmy2000ss's Avatar
Must be alot of damage I had 3 bad cylinders and never blew out the valve cover gasket (just the dipstick tube). Good luck.
Old Oct 16, 2006 | 08:42 PM
KissMySSo1's Avatar
was your valve cover tight?
