wastegate?
Old Oct 21, 2006 | 12:18 PM
BeaversTA's Avatar
Default wastegate?
I'm looking at getting a new wastegate and I'm wanting one that will bolt right up to where my old one is located. I curently have a deltagate. I was looking at the JGS 400 or a turbosmart 38mm they look like they will bolt right up. Any one know for sure if they will work?
Thanks
Old Oct 21, 2006 | 12:36 PM
ABeasst's Avatar
the JGS400 is the same size/bolt pattern as a tial 38mm, but I'm not sure what a delta gate looks like.
Old Oct 21, 2006 | 12:54 PM
BeaversTA's Avatar
A pic can be found here. http://www.turboneticsinc.com/valves_deltagate.htm
Old Oct 21, 2006 | 01:37 PM
bowtieman81's Avatar
The turbosmart will bolt up fine, thats what I have.
Old Oct 21, 2006 | 01:46 PM
BeaversTA's Avatar
Any one know if the JGS 400 will bolt up. If the turbosmart will the JGS 400 should right?
Old Oct 21, 2006 | 03:02 PM
navymitch12's Avatar
if the tial 38mm is infact the same size of the jgs400 then yes it will bolt right up
Old Oct 21, 2006 | 04:49 PM
SWINGRRRR's Avatar
I can have you some pics of the JGS on Monday. Mine should be here by then.
Old Oct 22, 2006 | 06:26 PM
BeaversTA's Avatar
Any one else have some info to throw in?
