20psi, is it time for colder plugs?
Old Oct 28, 2006 | 11:02 AM
parish8's Avatar
single digit dreamer
Originally Posted by Julio
Just a question, wouldnt it be a bad thing to shut down a turbo immediately after running it very hard.
I understand an NA motor, or blower.. the turbo???
yeah, i wont be trying that. i am going to run the 8's and see how it goes.
Old Oct 28, 2006 | 01:11 PM
qqwqeqwrqwqtq's Avatar
It's not something I would do every day, but the only way you'll know if you're running the right heat range is to read a plug.
Old Oct 28, 2006 | 01:18 PM
Julio's Avatar
life's about expensive decisions aint it
http://www.dragstuff.com/techarticle...-pictures.html
HTH
Old Oct 28, 2006 | 07:26 PM
TURBO8's Avatar
Originally Posted by parish8
i have been running "tr7"(br7ef) plugs. i am now pushing over 20psi at the track. is it time for the next colder plug or are th 7's still ok? i have a set the next colder plug, r5671a-8 wich some people like to call a tr8. i let the truck idle for a long time at the track, will the 8's foul out sitting there idleing?
I have run 25psi on my tr6's (accidently) and my plugs looked good. Should I change my plugs also? I only plan on running 20psi at the track the next time I go. I don't make no where near the power Parish makes, but I do run 20psi. should I think of a tr7 or tr8? I have not had to much detenation, I run a crap load of meth.
Old Oct 29, 2006 | 08:10 AM
Julio's Avatar
One thing I may throw out, my own car favors hotter plugs. Maybe due to the high amount of meth shot in. Or different chamber design.
I ran tr5's last night for an experiment.. no issues at 24 PSI. Car ran 6.7@104.8 wed night at 22 PSI. V6 Buick engine.
Old Oct 29, 2006 | 09:51 AM
parish8's Avatar
i am still running a fair amount of meth too even with the race gas.
hey Julio. i need more fuel up top. i have the 3bar map and am around 2.5bar boost. my initial is at 12oclock and turn on is around 10. my gain is all the way up. i have twin 15mm nozels. if i turn up the initial i get a lot more meth but it comes on so fast it is hard to tune around. is there a way i can get more meth at the higher boost levels without it hiting so hard down low?
Old Oct 29, 2006 | 05:13 PM
cablebandit's Avatar
bigger nozzles!!!
Old Oct 29, 2006 | 05:59 PM
Julio's Avatar
Are you needing the meth due to KR or your running out of fuel. If your running out of fuel then bigger injectors and fuel system. Trying to fix a fuel delivery issue with an injection kit.. is iffy. And more so with someone getting greedy with a boost controller
Hook up a pressure guage to the nozzles and watch it sweep up. If you hit over 150 PSI on the twins, you need to add more nozzle. In other words your running the system to its limit. I would not crank the Initial up on a setup like yours. That creates other issues. Call me and i'll square away your setup. If anything lets add a third nozzle. So we can make the system progressive showing you a constant increase in delivery. The higher the boost.. the more meth we'll flow in.. but only if your injector DC is low and your seeing KR
Old Oct 29, 2006 | 07:40 PM
parish8's Avatar
yes i am trying to make up for an iffy fuel system. i am out of pumps, line. injectors still have some room to grow. i am not ready to throw in a new fuel system.
Old Oct 30, 2006 | 05:31 AM
Julio's Avatar
Call me and lets work on the 3rd nozzle
Old Oct 30, 2006 | 08:51 AM
V6 Bird's Avatar
V6... Mike... Summit sells NGK's too.
Yes, they do...I just cant ever find them listed as a TR8
