help with turbo size
Old Oct 28, 2006 | 04:45 PM
bearcat's Avatar
Default help with turbo size
I have an lt1, 355, trick flow heads, 9.0:1 compression. m6. Im looking to make 500rwhp. Im not sure as to how im going to pick which turbo id need to use. anyone have any good links or anything? i need to know how to pick the right size. thanks for any help.
Old Oct 28, 2006 | 10:57 PM
Project GatTagO's Avatar
http://www.turbobygarrett.com/turbob...ch_center.html
Andrew
Old Oct 28, 2006 | 11:01 PM
LS2Camaro's Avatar
http://forcedinductions.com/help.htm
Old Oct 30, 2006 | 09:26 AM
DrTurbo's Avatar
LS1TECH Sponsor
Go with a TC70, it will make plenty of power and always leave yourself room for more power, cause you will want more.
Old Oct 30, 2006 | 09:09 PM
NOSjohn's Avatar
Restricted User
With the CI of that motor, I would stay around a 70 or 72. Read up on those links above...the more you learn, the better off you are.
Old Nov 1, 2006 | 01:17 AM
bearcat's Avatar
thanks for your help guys, sorry i didnt see the responses earlier. i appreciate it!
