Reason for switching to a carb intake??
if he lost boost due to the new intake having less restriction, then he should have gained power in the process because MORE air would have been getting into the system
now if they did the intake swap, and it wasnt sealing properly, he could have been loosing boost AND loosing hp, because air that was supposed to make it into the engine was just bleeding to atmosphere ... meaning less actual cfm made it into the engine
I have swapped so many things on this car, dropped compression, cam, exhaust, got rid of the LS1 MAF and my boost level really hasnt changed more then 1psi but the car is running 2-3mph faster in the 1/8 mile and thats a big change..
Logging 4th gear on the track from 5500rpm to 6900rpm.
My boost in July with the stock LS6/ stock ported TB and October with the carb intake.
Boost is identical, give or take 2-3kpa. ( ie virtually nothing )
Its not enough though to say 100% one way or the other. I'm only comparing 1 run with each.
I'll give an example at 6000-6200rpm, 4th gear. Slight variations in rpm, due to logging data itself, but not so much it should matter, as the trends are the same.
July over the 2 runs I have logged. All mid-high 10's 143-145mph. Thought I had 3 runs logged, but can only find 2.
Stock LS6 intake with DIY ported stock TB.
6001.2rpm........220.8kpa
6200rpm...........229.2kpa
6022.0rpm......216.3kpa
6202.4rpm......225.3kpa
Carb intake in October, over 4 runs, as close to 6000-6200rpm as I can get.
5990.7rpm......229.5kpa
6241rpm........234.8kpa
6028rpm........227.7kpa
6240.2rpm.....232.9kpa
5098rpm........226kpa
6230.2..........232.4kpa
6027.7rpm......228kpa
6206.4rpm......231.6kpa
Now, I did make slight alterations to my belt drive before October, that might have provided better grip. But I dont believe the July runs suffered any slippage.
I have no idea what rwhp I am making, as I dont have access to a dyno to find out, so has never been dyno'd in its current configuration.
while i am at it are you running a cog? or the s-belt? If it is an s-belt what did you do to alter it? i am thinking you are running the s-belt just for the fact you are a stick and i would think the shock of a hard shift would snap a cog belt.
the increase in boost with about the same power seems odd to me.
That to me would mean the carb intake is then a restriction, am i wrong?
I have boost pipes, very close to my belt, on the driven/long side. Watch how much the belt moves.
http://videos.streetfire.net/search/...1e0002aacc.htm
My setup is custom. YSi with a 12 rib, now using a Gates belt.
Previously, belts were shredding, I believe as the belt was allowed to build up vibrations, as there was a massive 19" or so without support on the driven side.
I added an idler there, reducing that to about 13". The idler is there just to stop any belt vibrations/wobble building up. It doesnt alter belt path to any degree.
The October weekend was circa 800 road miles, and 7 x 1/4 passes. I didnt have to do anything with the belt all weekend. I didnt re-tension it or anything, as everything stayed in check.
NOW...the runs in July were on a different branded 12 rib belt, and on the 4th pass it shredded shifting into 3rd. I dont believe I was having any noticable degree of slip though on the previous 3 runs.
The 2 logged runs were my first runs on that belt ( plus road miles ) and tension was checked immediately before the runs.
So assuming no slip on both setups, it would appear, the carb+85mm TB is posing more of a restriction, on my setup at least.
This would also be backed up, by the fact my tune changed very little. Its very hard for me to give a %% on fuelling, as shortly before I also swapped iinjectors from 660cc to 73lb. I did get a brief baseline tune with the new iinjectors, before switching the intake, and as already mentioned, fuelling requirements changed very little.
Due to how my ecu works, I do rely quite heavily on closed loop wideband to take control of fuelling, and quite often I do change my AFR targets.
But I was surprised, that overall inj pulse widths didnt change much.
Go figure....
of course it also brings the question...
If I am experiencing this....why hasnt anyone else ? Surely I cant be alone ?
its just a basic Victor nr, with typical elbow using a Accufab 85mm TB ( whats the point in going bigger, when IC pipework is 3" )
i'm sure in theory it "should" work better but other than looking cool under the hood i'm not convinced its superior than the stock ls6 manifold (assuming the car is making 1000 hp or less)
But n/a can be so different to FI ( and indeed, Edelbrock offer different cams for carb applications )
Too many variables, and no apparent back to back testing has been done. So everything is guess work really.
so what is it?
lol!! Currently im running a fast90mm and i wanted to ste up to a card/105mm tb. However, i wanted to see the difference between the two power and number wise. Ya'll think the fast will hold up to boost since it is a three piece unit?
I dont recall having seen any threads, where a FAST has gained power over stock LS6 intake on a FI motor.
And again....if your IC pipework is 3" or 76mm ( I assume ).
Whats the point in a 105mm TB ?????
could it be that your heads now cant keep up with the added air flow of the intake?
i would "think" if that where true you best turbo would be sized about 76mm with a proper ar. but it doenst work that way... i think..
IMO I dont think you made a bad decision on doing that intake, obviously you are doing a fairly high dollar build and since most of the faster cars out there are using them it makes perfect sense to use one. Like I said earlier on a F1 engine I dont think the intake is going to make or break the combination.
