Good Electronic Boost Controller?
Old Dec 13, 2006 | 06:20 PM
  #41
Jon B.'s Avatar
Originally Posted by Phil99vette
The best boost controller on the market hands down.
www.ams1000.com
It better do more than control boost for $850!
Jon
Old Dec 13, 2006 | 06:24 PM
  #42
NOSjohn's Avatar
Restricted User
If you guys need help with the eBoost, feel free to give me a call. It is really more controller than most of us need. A simple manual controller is all you really need. Save yourself $400.
Old Dec 13, 2006 | 09:57 PM
  #43
RW99's Avatar
Thanks, John... it's more an uneasy feeling when I'm trying to go through the menus to inspect the settings... I worry that I'll enter editing mode and futz up the value. I think I just need to spend some more time with it.
Old Dec 13, 2006 | 10:04 PM
  #44
NOSjohn's Avatar
Restricted User
Correct, read through the manual over and over if you have to...no harm in it. If you need help, feel free to call. You're welcome~!
Old Dec 13, 2006 | 10:40 PM
  #45
B18CYA's Avatar
I loved my profect B worked great for all 5 years i had it.
With they steering wheel remote make it very easy change boost between gears. A must when you stat making more power then your tires can hold.
Old Dec 13, 2006 | 11:20 PM
  #46
Jammer's Avatar
The Eboost may be $450, but in that price you also get a nice looking gauge....
No comment on operation yet...still waiting for NEW Era to send me mine (had to return lat one for a different color) Cant beleive they dont offer a 66 mm in black! I chnaged out a silver for a white.
Old Dec 14, 2006 | 03:42 AM
  #47
VINCE's Avatar
Shorty Director
Is there one for the LSX cars that will allow you to set boost via gears or speed?
Old Dec 14, 2006 | 11:31 AM
  #48
RW99's Avatar
Yes, EBoost2 will allow you to customize your boost via referenced input.
You can download the manual from here:
Turbosmart downloads...
Old Dec 14, 2006 | 02:05 PM
  #49
HAMRHEAD's Avatar
Innovative here
Old Dec 14, 2006 | 03:22 PM
  #50
Firechikn's Avatar
Ya, I knew I was in trouble when the controller didn't have a owners book, just a simple getting started page. You have to download the complete instructuions. They can't fit a encyclopedia sized book in that little box.
Old Dec 14, 2006 | 03:42 PM
  #51
SSilverSSurfer's Avatar
is the eboost 2 a boost gauge and a boost controller?
Old Dec 14, 2006 | 04:16 PM
  #52
DrTurbo's Avatar
LS1TECH Sponsor
Yes it is...
Old Dec 14, 2006 | 04:24 PM
  #53
Originally Posted by DrTurbo
Yes it is...
awesome, i guess im gonna order this instead of ordering a boost gauge and a a man. boost controller
Old Dec 14, 2006 | 05:00 PM
  #54
1INSANEGTO's Avatar
I am going with the Eboost2 cause its a badass setup and I do not need to buy all that stuff with a reg meth kit. I only need pump lines and nozzle and the eboost2 can turn the pump off and on via boost setting
Old Dec 14, 2006 | 05:30 PM
  #55
LS2Camaro's Avatar
A Meth Kit is a entire different setup, Lets you run more octane. has nothing to do with boost. Keeps your IAT cooler.
Old Dec 14, 2006 | 06:44 PM
  #56
1INSANEGTO's Avatar
Uhhhhh Eboost2 can be set to turn the meth pump on and off at a set boost setting.
Which you would not need a meth controller.
Check this average meth kit costing $250.00
Now you have a Eboost2 already which is a boost controller and a gauge. Now you buy this http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Use you water tank for your wipers as your tank (alot of people do this) and you saved how much?
Hope you get my point now
Old Dec 14, 2006 | 07:20 PM
  #57
thats not a bad idea
Old Dec 14, 2006 | 07:52 PM
  #58
RW99's Avatar
...unless you want progressive methanol spray. The Alkycontrol kit (and others) uses a boost reference to apply varying amounts of methanol: more boost, more methanol. I like having that level of control.
Your EBoost2 control of the methanol switch would be on/off.
Old Dec 14, 2006 | 08:00 PM
  #59
1INSANEGTO's Avatar
Voltage effects flow so in turn yes you can turn up the spray level
Old Dec 14, 2006 | 11:47 PM
  #60
RW99's Avatar
EBoost2 auxiliary output will use RPM or Boost readings as the trigger, but only opens/closes its switch for external device control. Unfortunately, no in-between.
That said, though, you could use a boost setpoint of about 60-70% of your max boost and perhaps that trigger point would start the methanol at the appropriate time. You'd really want to watch your A/F when that happens, though.
