Procharger Intake Air Temps IAT
Old Nov 15, 2006 | 09:29 AM
mondi2002's Avatar
Question Procharger Intake Air Temps IAT
I recently installed an aeroforce guage in my car
I am really obsessed with my temps now!
Just dont know what is normal?
This morning it was in the 40's outside & cruising my
intake temp was in the 50's but spiked up to 85!
Sustained full thottle. I cannot imagine what it is when
its hot out. I am running the bigger procharger intercoolers,
and 8psi boost. Probably will never run more that 11psi
or 650RWHP max. I am at 500RWHP on the Dynojet now.
I have been thinking of intalling a LT1 radiator to help my
coolent temps. So last night I took a look at my radiator
and I had some crud in it. I vacummed most of it out.
I ended up ripping out all the plastic dam. Not the bottom one.
(2pcs in front of the AC Condenser) I was thinking opening it
up would help with stop & go temps, BUT may be bad for
Air intake temp because the Intake Plenum is right above it.
I cant believe that the procharger heats the air that much.
Old Nov 15, 2006 | 09:38 AM
kp's Avatar
kp
Take the intercoolers off and see what happens
That seems about normal for the stock twins, my car goes from 80 to 130* on a 65 degree day in 9.3 seconds with a giant front mount IC. Compressing air makes heat, cant do much about it.
Old Nov 15, 2006 | 11:39 AM
LSs1Power's Avatar
It seems normal... I had a temp increase of 40-50 degrees when i was running 8psi and around 70F when i was running 13psi. I had the 3.5" intercoolers though. Do u have the plastic deflectors installed right under the intercoolers? I mean are they titled to push air upward or downward? Some people have them titled the wrong way which could make them less efficient.
Old Nov 15, 2006 | 12:02 PM
RW99's Avatar
Question
Sure you can, although I know I'm not telling you anything new.
Why not add a methanol kit? That makes watching your IAT's very fun:
I'm not sure how useful a 25 degree IAT is, but the point is that you can drop ambient by over 30 degrees. I'm using the Alkycontrol kit, mine starts to ramp in at about 3 psi. Max boost on that graph was about 11.3 psi.
Old Nov 15, 2006 | 12:21 PM
andereck's Avatar
Ya, maybe you can explain your graph to us? That doesn't look like a boost "curve" I've ever seen. Is the time scale extremely compressed? You make 13+ psi instantly?
55 in HG/2 -14.3 or so for atm press.
Overdriven roots flipping the throttle open for a flash?
Old Nov 15, 2006 | 12:27 PM
mondi2002's Avatar
Question
Yeah thet have the flaps on them but they are
pretty much level. I was thinking of shimming the back
of them down to catch more air.
Would venting the bypass valve to the atmosphere help?
What size filter would I need for the extra spot on the hat?
Old Nov 15, 2006 | 12:30 PM
RW99's Avatar
Sorry. It's just an autotap log from a little freeway driving. X scale is in seconds; Y scales are MAP in blue (inches Hg) and IAT in orange (degrees F). The boost "spike" is just me going WOT for maybe five seconds or so.
And yes, (~53 in. Hg X 0.4912) - 14.7 for the boost psi calculation. Also what the Eboost logged for max boost on that little run.
Old Nov 15, 2006 | 12:34 PM
LSs1Power's Avatar
My valve wasnt vented to atmoshpere at the time. I read somewhere that people had better results with them vented to the atmosphere.
Old Nov 15, 2006 | 12:37 PM
No Juice's Avatar
yeah I'd like to know if you can vent it to the atmosphere too
Old Nov 15, 2006 | 12:44 PM
kp's Avatar
kp
IATs will stay down a little while cruising with it vented to atmosphere, but you will pick up a lot of noise.
Old Nov 15, 2006 | 01:03 PM
andereck's Avatar
Thanks for the clarification and the info.
I have some non-intercooled logs from a carbureted car, but I doubt anybody is interested in that here. I currently measure SC inlet, hat and plenum temps. So far the carburetor is pulling over 90 degrees out of the air at max boost. This is a similar phenomenon that could be experienced by methanol, though injected methanol is going to be at a lower volume.
Rolling down the road the fuel will drop the temp in the plenum below inlet. The SC adds about 20-30 degrees to the inlet temp depending on how fast I'm driving and the blower is spinning.
Old Nov 15, 2006 | 01:31 PM
Ferocity02's Avatar
When I had a Procharger with the older style twins, my IAT's were around 110 on the dyno with large blowers on each intercooler, the outside temp was around 75.
Old Nov 15, 2006 | 02:39 PM
Mark98SS's Avatar
Those twins don't get a whole lot of flow & the total surface area is pretty small. A 12x24 front mount will drop the IATs by 30-40 down the track.
Old Nov 15, 2006 | 03:54 PM
mondi2002's Avatar
I really dont want tear up my front end.
May be able to fit one in front of the Air dam.
Old Nov 15, 2006 | 07:00 PM
andereck's Avatar
I have yet to see any definitive back to back tests on the twins vs. a front mount. The twins work much better than many give them credit for. The F-body is a bottom breather and they get substanitial air. Even high output "blue fans" can't come close to match the air volume and velocity of on road/track use. I want to see some data on pre I/C and post I/C temp with both setups, and not just factory OBDII IAT data from one point.
Old Nov 15, 2006 | 07:48 PM
CraZee ZO6's Avatar
Id like to see a comparision of the NEW STAGE II kit twin intercoolers that are sheetmetal and 4.5"
About to put that kit on my zo6. I think belt slip problems have been totally eliminated with this new kit as well.
Old Nov 15, 2006 | 08:04 PM
kp's Avatar
kp
I have to agree, as far as cooling goes the bigger twins probably dont do as bad a job as many think. The smaller ones were just fine at 10psi for me and you didnt have to cut a big hole in your bumper. Biggest gain from the FMIC is a lot less tubing and bends I would imagine, there was a guy in california (silver bullet) that ran 9.70s with a D1SC a couple years ago with two of the smaller twin ICs in series used as a FMIC. He is on the 2004 boosted list still.
Old Nov 15, 2006 | 08:27 PM
LSs1Power's Avatar
I can give you an answer on this once everything goes back together. I can leave the same pulley i had on the blower just for a few runs to log in the IAT. We were reaching 140F in 70F ambient at 13psi. We will see what the IAT increase with the FMIC.
Old Nov 15, 2006 | 08:32 PM
andereck's Avatar
Excellent, keep us posted.
Old Nov 16, 2006 | 09:42 AM
E.A.'s Avatar
YES!!!
Venting to the Atmoshere, helps normal driving IAT's A LOT!
As others have stated the trade off is the sound. It's a bit louder with the air rushing around. I place filters on the ends of the Bypass valve, not to keep the dirt out (cause it's always blowing out) but to just hush the sound a bit on street cars.
Most people plug the hole in the hat with some form of rubber cap. Or take a peice of hose, then place a metal plug in the end of the hose.
Hope that helps,
EA
