Possible Turbo Problems? HELP!!!
Old Nov 15, 2006 | 12:27 PM
JD_Z28's Avatar
Default Possible Turbo Problems? HELP!!!
When I hit boost I noticed the car dosen't pull like normal and I get a sputtering sound when going into boost. When I reach full boost it tends not to hold it, the boost fluctuates up and down about a pound or so. I can also hear a piece of something inside the intake manifold ticking around like something got sucked in there. What do you guys think the issue might be? I'm guessing its the turbo so i'm goanna check it today. Does anyone have any advice.
Old Nov 15, 2006 | 12:50 PM
TransAm6383's Avatar
if you think something got sucked in..check the blades on the compressor wheel.
Old Nov 15, 2006 | 12:53 PM
JD_Z28's Avatar
Thats what i'm going to be doing later today. Do you know who sells good turbos on here.
Old Nov 15, 2006 | 12:56 PM
LS2Camaro's Avatar
forcedinductions.com
Old Nov 15, 2006 | 12:58 PM
JD_Z28's Avatar
Thank You sir
Old Nov 15, 2006 | 01:20 PM
DrTurbo's Avatar
LS1TECH Sponsor
Yes, give us a call, we may can help.
Old Nov 15, 2006 | 01:28 PM
JD_Z28's Avatar
I just called you 5 min's ago
Old Nov 15, 2006 | 01:56 PM
DrTurbo's Avatar
LS1TECH Sponsor
Ahh guess you spoke with Jose or Jason then...lol
Old Nov 15, 2006 | 02:45 PM
Ping King's Avatar
did you ever pull the inlet off the turbo?
Old Nov 16, 2006 | 10:05 AM
JD_Z28's Avatar
No I haven't. I think I found the problem it might just be a poosible missfire, I replaced the plugs and wires and that didn't help so i'm guessing it a coil pack.
Old Nov 17, 2006 | 09:52 AM
JD_Z28's Avatar
I finally found the problem. It looks like I bent a valve spring and bent a push rod I guess now I have to see if I can get these parts warrantied.
Old Nov 17, 2006 | 08:54 PM
RooRnZ28's Avatar
which springs/ rods did you have?
Old Nov 17, 2006 | 11:08 PM
98turbls1's Avatar
Comp Cams 921 springs and trick flow 7.35 push rods...
Old Nov 18, 2006 | 06:53 PM
RooRnZ28's Avatar
looks like its time to step it up to patriot duals....
