Sanity check my PCV and vacuum lines.
Took the pcv line to a one way valve to keep boost out, kept the pcv valve inline to a catch can, then on to the intake manifold.
Just blocked off the TB inlet since the inlet is now at the airfilter.
Only thing you might want to change later is the reference for the boost controller if you go electronic. Reference to the manifold will work better for an electric controller since most will give a boost/vac reading and will compensate to the pressure drop through the maf/tb.
