D1 402 numbers
Old Dec 10, 2006 | 04:40 PM
Jimmy P's Avatar
At first the FP was at about 63psi, and the injectors were maxed out and it was going lean at high rpms. The tuner then raised the FP to about 71psi and then he could richen it up.
It was a complete fuel system, with a external Magnafuel 4303 pump, braided lines, and boost referenced Magnafuel regulator.
Old Dec 10, 2006 | 06:32 PM
ty_ty13's Avatar
7 Second Club
this spring ill have my 408 with a th350 and d1sc out and try to make a dyno trip... that much torque doesnt suprise me at all... what do you expect with a small pulley and a 4'' stroke and a unlocked converter...
Old Dec 10, 2006 | 06:52 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Nice numbers, 93 pump gas? Nile still tuning the car?
Old Dec 11, 2006 | 10:59 AM
300bhp/ton's Avatar
Originally Posted by unit213
Wow...that doesn't even look like a centrifugal graph. How in the world are
you making so much torque down low like that? That's some real nice power
through a TH400.
I think it's due to the torque multiplication of a large unlocker torque converter.
Occasionally you'll see n/a 346ci's making 500lb ft at under 3000rpm, but again this is because they usually have a 4400rpm stall or equiverlent, there's quite a few examples in the dyno forum.
You'll see most dyno's for high powered auto's usually start out at 3500rpm, I think it's partly to aviod this.
If you had an auto in you Terminator it would also show up some spurious torque figures down low.
Old Dec 11, 2006 | 01:12 PM
Jimmy P's Avatar
The car was tuned at Nile's shop, but not by Niles. I had my tuner meet me there. Yea it was on pump gas.
Anyone know the part number for plugs that are 1 range colder than the TR6's?
Old Dec 11, 2006 | 01:44 PM
kp's Avatar
kp
Thats exactly what it is, typical procharged car will make its peak torque much higher.
Dynojet sort of fixed the RPM being off and the big torque spike with large stalled autos with winPEP 7, I have no idea how they handle it on a mustang dyno.
Numbers look strong, dont worry about the dyno on a high stalled auto, get what you can out of it and run the car at the track. Since you have a TH400 I assume thats what you want to do with it. Leave the dyno racing to M6s and autos that can lock the converter
Old Dec 11, 2006 | 02:48 PM
BOONE's Avatar
BP7EFS stock #3526
Old Dec 11, 2006 | 04:52 PM
LS1Tech Co-Founder
Jimmy you live around Chicago?
Like kp is saying, unlocked auto's are hard to dyno and you are not going to have anything to brag about on the web compared to the M6 guys. I'd say you have enough figured out that you should just be making some hits on the street and seeing what falls off, and then at some point waiting for the tracks to open.
Old Dec 19, 2006 | 01:02 AM
Jimmy P's Avatar
John
I live in the N. side of Chicago. I do understand that it wont be a dyno queen. Have to get some slicks and hit up the tracks when its warmer.
Old Dec 19, 2006 | 01:31 AM
ChaseSS's Avatar
those are awesome numbers, a 402 with a D1 and 6.0 heads is what I was wanting to eventually build once i am out of college, what kind compression ratio did you build that motor at?
Old Dec 19, 2006 | 08:06 AM
ty_ty13's Avatar
7 Second Club
what size crank pulley do you have? is it the 7.626 (the stock 8rib one?)
Old Feb 23, 2007 | 04:46 PM
  #32
EPP's Avatar
EPP
Exclamation
Hey, I tried to pm you back, but your box is full. Bob
Old Feb 24, 2007 | 11:51 AM
  #33
ty_ty13's Avatar
7 Second Club
you dyno looks almost like mine... my HP peaked at ~5700rpms at 572rwhp.. we had to start our pull at about 4k though since my converter was flashing sooo high....
i drove mine yesterday.... i can be doing 60mph and be in high gear and stuff the pedal and the nose comes up like a boat while its frying the tires and will hold like that till i let off....
very fun stuff....
  #34
CougarL92's Avatar
Nice numbers
