sts wont boost
Old Dec 15, 2006 | 09:11 AM
Travizzle's Avatar
Sorry to here im going through the same crap. I only made 2# barely. I have heard putting hair spray in all the silicone couplings, once they dry they seal up pretty good. Im giving it a couple of more trys then the nitrous is going back on.
Old Dec 15, 2006 | 09:23 AM
bud8fan's Avatar
too bad billy(trt) is in florida...i think he could give some good insite on this issue since he has installed these kits on alot of f bodys with and without headers-wraped and unwraped...he'll be back sunday...maybe he will chime in....
Old Dec 15, 2006 | 09:24 AM
TNTramair's Avatar
check all your couplings...HSW had a STS car in the shop with the same exact problem and it ended up being a very small tear in one of the hoses.
Old Dec 15, 2006 | 11:23 AM
GR33N GoblinM6's Avatar
rip that **** off and send it back to "JOE" at STS..
Old Dec 15, 2006 | 12:12 PM
RooRnZ28's Avatar
i have been on the phone with billy for the past few days, he is really a great help.... even though he is in florida, he is still trying to provide some insight for me. i'm just gonna have to keep trying things.... thanks for all the input and any more is greatly appreciated!
Old Dec 15, 2006 | 12:28 PM
edcmat-l1's Avatar
Originally Posted by RooRnZ28
would they be able to tell if they took the turbo apart? because they did....
If they took it apart I would guess they would know if it was seized. Can you get to a dyno? That way you could run it under some load and check for leaks. Can you hear it spoolin? If its spoolin the airs gotta go somewhere. I know, master of the obvious, right?
I would wonder why they took it apart. If its not seized, why would they take it apart?
To see how it works? To see if it had an internal air leak? OK, now I'm just being a smart ***, sorry....
Old Dec 15, 2006 | 12:30 PM
edcmat-l1's Avatar
I would think with a small leak you would still get SOME boost...
Old Dec 15, 2006 | 12:40 PM
kidcamaro98's Avatar
you could have a bad coupler and you wont be able to tell while its on the car and sometimes even checking it theroughly because say if you ARE making boost and the air reaches that coupler, it will then expand, letting the air out and the boost not reaching your intake manifold. In most cases this happens on the coupler going into the intercooler and comming out.....what types of clamps are you using to fasten them?? please tell me they are T-bolt clamps and not the shitty hose clamps cause once you boost with hose clamps they loosen up and the coupler blows off the piping. As far as the wastegate goes....you HAFTO hook up a vac. source. If you dont (it still wouldnt prevent you from getting boost) the wastegate will NEVER open and that means BOOM on motor. The wastegate is controlled by the vac. line going into it and the LB spring thats in there. If the wastegate never opens, you will see never ending boost untill your motor blows up. So before you even try to find the boost leak, fix this up incase they do get it to work and then she will blow up. Check your BOV too. The valve could be stuck somewhat open also creating a boost leak. I doubt its a exhaust leak because you should still get something for a spool....good luck
Old Dec 15, 2006 | 01:33 PM
Blackbird's Avatar
ask them to pressure test it.
pcv pipe with a cap on the end. screw in a air compressor fitting.
connect that to one end of the system back by the turbo.
fill with 10psi of air, listen for leaks.
simple as that to see if anything is leaking.
Old Dec 15, 2006 | 03:59 PM
RooRnZ28's Avatar
yes, right now it is at a speed shop getting tuned...
well before i took it to get tuned, i started it up with the kit on and no tune and revved it up pretty good to see if i could hear the turbo at least spin, but i never did hear anything. i have seen vids of people rev up their sts, and you ususally can hear the turbo at least spin, but it didnt happen that way with me..... i just figured it was all tuning?
and i guess they took it apart to check it out? i dont know, but they told me there is nothing else they can do, and thats when i asked what have they done already to check it..
and yes, tbolt clamps all the way!
Old Dec 15, 2006 | 04:26 PM
Blackbird's Avatar
yah once the car is warm when you rev it you should be able to hear some whistle.
Synergy has installed at least 2 dozen of these things, it must be something really wacky.
Old Dec 15, 2006 | 06:22 PM
  #32
edcmat-l1's Avatar
Damn good idea. Does the shop have a smoke machine? No, not an electric powered bong. We have a smoke machine for finding vacuum leaks. It would probably work great for that too. Just a thought.
Old Dec 15, 2006 | 09:25 PM
  #33
RooRnZ28's Avatar
well they said they checked the intake side and the exhaust side... i dont know how exactly, but hopefully they did what you said.
Old Dec 17, 2006 | 03:57 PM
  #34
trtturbo's Avatar
Wish I could help more. I know Rick an Synergy can figure it out.
There are not issues with the STS making boost. There is an issue, and more than likely a small one that is keeping it from boosting.
Johnny, I will make this offer. If you want to pay for air fare, I'll send a guy to California to look at it for you.
Old Dec 19, 2006 | 10:19 PM
  #35
j88l98irocz's Avatar
do you want to sell the sts kit ?
Old Dec 20, 2006 | 04:37 PM
  #36
RooRnZ28's Avatar
well it turns out that the turbo was indeed seized.... so what does that mean?? do i need to get a new one?
Old Dec 20, 2006 | 04:57 PM
  #37
Blackbird's Avatar
or get it rebuilt, is it a new kit? I would think STS would warranty it unless there was some installaion error
Old Dec 20, 2006 | 05:18 PM
  #38
Slowhawk's Avatar
LS1Tech Sponsor
Yes,if the kit is new STS should warrenty it easilly enough.
Old Dec 20, 2006 | 07:08 PM
  #39
RooRnZ28's Avatar
yes, i bought the kit brand new like 2 months ago from billy at TRT... hopefully sts will replace it
