Cobalt SS MAP sensor?
Old Dec 19, 2006 | 06:59 PM
SELLSZ06's Avatar
Default Cobalt SS MAP sensor?
Iam almost done with the Hiflo install, so now Iam looking for a tuner. I think I found one here, but he wanted me to replace my MAP sensor for a bar2 sensor found on the Cobalt SS/Ion. I never heard of that, especially since I had a tuned using my stock MAP sensor b4. Anyone heard or done this?
Old Dec 19, 2006 | 07:02 PM
dschmittie1's Avatar
I have heard of this. I was told by a tuner to do the same thing when I am ready to get my car tuned. It makes it easier for them to tune and is safer. because a stock MAP will not register boost but the cobalt MAP will.
Old Dec 19, 2006 | 07:15 PM
ABeasst's Avatar
Its actually a 2.5BAR and if you look at this thread it lists most of the used MAP sensors. https://ls1tech.com/forums/forced-induction/310536-2-bar-map-sensor.html
Old Dec 19, 2006 | 07:17 PM
SELLSZ06's Avatar
cool, Ill probably try it, just wanted to check
Old Dec 19, 2006 | 07:39 PM
frcefed98's Avatar
Stickied at the top
https://ls1tech.com/forums/forced-induction/208864-turbo-faq.html
Look towards the bottom of the Turbo FAQ's
Old Dec 19, 2006 | 08:15 PM
2002ws-6's Avatar
I'm getting mine tuned wednesday with the 2.5bar map sensor using HP tuners you just have to cut off the mounting tabs on the right side to fit in the stock location. Theres a few pictures floating around here just search for 12580698. I expecting good results, should be able to hold a nice 11.5:1 A/F at WOT
Old Dec 19, 2006 | 08:16 PM
2002ws-6's Avatar
also buy a new grommet, mine was not reusable and its cheap part number 16194007
Old Dec 19, 2006 | 08:35 PM
SELLSZ06's Avatar
so its something worth investing on before I tune right?
Old Dec 19, 2006 | 10:39 PM
onfire's Avatar
Coal Mining Director
#12580698 is a 2.0 bar map sensor. It is the BAP sensor for the Cobalt SS / Saturn Ion. They use a separate MAP sensor that is 2.5bar but has an integrated IAT sensor. That's why it gets confused with being a 2.5bar when it's only a 2.0 bar sensor.
Old Dec 20, 2006 | 08:50 AM
ty_ty13's Avatar
7 Second Club
im using that map sensor from the redline ion......
Old Dec 20, 2006 | 09:57 AM
JMBLOWNWS6's Avatar
Extact one I am using
Old Dec 20, 2006 | 09:58 AM
PurEvl's Avatar
Thats what i use
Old Dec 20, 2006 | 12:18 PM
SELLSZ06's Avatar
Ill buy one then, it works.
Old Dec 31, 2015 | 03:31 PM
JosenaVega's Avatar
So I hooked a computer to my 2006 cheverlot colbalt ss and read crankshaft sensor replaced that the it read the other crankshaft position sensor replaced that and still my car turns over but still doesn't start so I googled about my car not starting so I replaced the map sensor because someone else had the same problem but my car is still not starting please someone help me
Old Dec 31, 2015 | 03:36 PM
JosenaVega's Avatar
Does anyone have a 2006 cheverlot colbalt ss
Old Jan 1, 2016 | 03:33 AM
RonSSNova's Avatar
This isn't a cobalt forum.
Have you tried here:
http://www.cobaltss.net/forums/
I actually do have an 06 SS/SC btw.
Ron
