Tranny and rear diff gear ratio for TT Vette??
Old Dec 24, 2006 | 09:39 PM
VINCE's Avatar
Shorty Director
Default Tranny and rear diff gear ratio for TT Vette??
If you had a 6 speed setup like the one I have in my signature what tranny/gear ratio would you run to optimize zero to 200mph sprints?
Old Dec 24, 2006 | 09:48 PM
rookie89's Avatar
FRC Tom(his name on Z06vette) uses a 2.73 rear gear with a 402 & STS with upgraded turbos and alot of boost. You'd only shift 2 or 3 times before 200 lol. He's also used 3.15s which he said made a difference. A local here in Houston is putting 3.15s on his 408 STS TT
Old Dec 24, 2006 | 10:20 PM
pianoprodigy's Avatar
FRCs come with an M6 tranny which is a .74 5th gear. With a 3.42 final drive you would be going 206 mph at 6750 RPM (assuming a 26" tall tire).
If you had an M12 (which has a .84 5th gear), you would want a 3.15 final drive which would put 204 mph at 7k RPM in 5th (assuming a 26" tall tire).
Old Dec 24, 2006 | 10:36 PM
VINCE's Avatar
Shorty Director
So are you suggesting I leave my current setup alone since I have the M6 transmission with my current setup?
Old Dec 25, 2006 | 10:21 AM
stevieturbo's Avatar
How much power/torque do you have, and where is it created. Do you anticipate 200 in 5th or 6th gear ?
Punch a few ratios into this, and see where 200mph will fall to tie in with your max power/torque.
http://www.geocities.com/z_design_st...ion_z28_6.html
Old Dec 26, 2006 | 12:36 PM
Yes, unless you wanted to start going into the tranny and changing gear ratios and even then, I'm not sure you would notice a substantial benefit.
Old Dec 28, 2006 | 04:35 AM
VINCE's Avatar
Shorty Director
I just want to optimize what I have
Old Dec 28, 2006 | 05:52 AM
then check your current speeds, versus rpm's and play with them in the calculator to see what may work best.
If you could be pulling 200+ just around max power/torque, or perhaps a little over 200mph, then you should be fine.
Old Dec 28, 2006 | 07:05 AM
VINCE's Avatar
Shorty Director
Why do I need to worry about 200mph? I get to 200mph pretty quick.
Old Dec 28, 2006 | 08:42 AM
Consider yourself optimized.
Old Dec 28, 2006 | 09:58 AM
oops....someone asked about 200mph in another thread....got my wires crossed
Old Dec 28, 2006 | 10:33 AM
VINCE's Avatar
Shorty Director
I am just trying to keep up with you
Old Dec 28, 2006 | 10:40 AM
Got Me SOM's Avatar
when you gonna drive that tt vette over to Orlando to let us check it out?
Old Dec 28, 2006 | 10:48 AM
VINCE's Avatar
Shorty Director
As soon as I get back from Afghanistan.
