Hi-flo problems, go figure! (pics)
Old Dec 25, 2006 | 10:51 PM
Abdullah's Avatar
looks like Dave idea is a good idea.
Old Dec 25, 2006 | 11:27 PM
Jammer's Avatar
Dave is always right BTW.
Old Dec 26, 2006 | 01:22 AM
2002/Black/SS's Avatar
Originally Posted by Brains
You're putting a TURBO KIT into the engine bay that's barely large enough for the motor itself. You should pretty much expect having to tweak things here and there. This isn't like installing a Tornado in your intake tube, this is a real modification
uuumm is this u talking to me like im a child who doesnt know what a turbo kit is? haha, because thast what i get from reading it
Old Dec 26, 2006 | 02:52 AM
2MuchRiceMakesMeSick's Avatar
hes just saying that what you are trying to do is not easy. it takes a little bit of work and im sure its not over yet. i would go with braided line
Old Dec 26, 2006 | 07:32 AM
RealQuick's Avatar
Have you considered whacking the crossover with a hammer to create some clearance ??
Exactly... a little flat spot would GEt R DUN.
Old Dec 26, 2006 | 11:13 AM
V6 Bird's Avatar
Originally Posted by 2002/Black/SS
the only way to fix it using the turbo crossover would be get a new pipe or extension, which im considering
clearance the tubing with a hammer!
Old Dec 26, 2006 | 11:15 AM
V6 Bird's Avatar
Ill say it for him. YES!
Old Dec 26, 2006 | 11:26 AM
Brains's Avatar
I'm saying it like that for comedic value Seriously though, such a minor clearance issue is not a problem, just something you'd take 2 minutes to take care of. You want to talk clearance issues? You should see what I had to do to make the Raymer/Stainless Works kit fit
Old Dec 26, 2006 | 01:33 PM
im not worried about the cleareance i can fix that, what REALLY bothered me was i was under teh impression no one else had this problem with their kit, as in i have a major problem with mine, thast y i asked! also the real fun starts when i have to tap the front of the oil pan!
Old Dec 26, 2006 | 03:05 PM
Brains's Avatar
That's the thing with kits like these - no two fit exactly the same. Its quite possible you'd be one of the few or even the only one to have an issue in that area, while others may have problems elsewhere. I've seen engines sit in the engine bay a full 1" different from car to car!
Don't fret tapping the pan, its not that bad. Just take it slow and be careful. If possible, do it off the car so you can flush out the shavings.
Old Dec 26, 2006 | 03:39 PM
im attempting to tap the timing cover to keep shavings out
