Rearmount WG question
Old Dec 26, 2006 | 11:11 PM
EGash's Avatar
Default Rearmount WG question
What size WG are you guys using on large (T70-T76) rearmount single turbo systems? Are you using the standard 38mm WG that comes in the STS kits or upgrade to a 44? What WG is being used on custom rearmount kits?
Would a 38mm WG on a rearmount 76GTS .81 and be able to hold boost to 7-8psi, or would it have creep problems?
Thanks,
Old Dec 27, 2006 | 08:38 AM
OUTLAWZ RACING's Avatar
I have a gts76, Im still using the 38mm 44mm is good you will have less boost creep at higher levels.
Old Dec 27, 2006 | 09:55 PM
EGash's Avatar
How stable is the boost level on your setup with the 76 and 38mm gate? Any creep issues?
