3 bar and 96# inj question
Old Jan 3, 2007 | 02:25 AM
ninetres's Avatar
Default 3 bar and 96# inj question
Can the stock PCM push some 96# injectors with a 3 bar? I got confused reading a FS ad for an injector driver. What's the scoop? Thanks.
Old Jan 3, 2007 | 05:34 AM
Inspector12's Avatar
TT-TECH Veteran
To run Low impendence injectors you have to run a different type of driver to convert our PCM driver to be able to run them as are cars are setup to run High impendence injectors, there are a few different companies that make them. As far as the 3 bar goes a lot of people are using HP Tuners 3Bar setup on there high hp FI cars. So I guess to answer your question Yes the stock PCM can run both with a little help.
Old Jan 3, 2007 | 06:04 AM
cablebandit's Avatar
you can do it with the AEM injector driver i have for sale in the FS section
they are made by AEM...Versafueler and I think Harlan made/makes one
Old Jan 3, 2007 | 07:13 AM
smokinHawk's Avatar
check in the PCM section there are some threads about it there in the correct section
