Crank set up for Procharger...
Old Jan 3, 2007 | 09:10 AM
Hocky's Avatar
Default Crank set up for Procharger...
I am looking to purchase a shotrblock with a crank is set up for an ATI pin drive balancer, but I don't have any intention of running a procharger. Will I be ok to slap a stock crank pulley on this and run it?
Old Jan 3, 2007 | 10:34 AM
kp's Avatar
kp
Wont hurt anything at all, if the crank is cut for a square keyway you may want to fill the slot with some silicone if its cut all the way to the pump drive gear to keep oil from seeping out. If it has the two round holes drilled you dont have to worry about silicone.
Old Jan 3, 2007 | 11:03 AM
Hocky's Avatar
Excellent, thanks for the info. :-)
