Best FI cam?
Old Jan 6, 2007 | 02:22 AM
seabirdak's Avatar
Default Best FI cam?
I was curious of any suggestions for a FI cam for a Procharger supercharger or STS turbo set up. Has to be streetable and easy to drive everyday.
Old Jan 6, 2007 | 03:08 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
If you have to ask, just get an '02+ zo6 cam. If you want a real answer, use the search function and do a lot of reading.
Old Jan 6, 2007 | 03:15 AM
95 Z28's Avatar
Thunder Racing sells a couple choices of FI cams...check it out.
spy2520's Avatar
i've been reading for a while on the same topic. still have no clue...i guess i'll be more thorough when i actually have money for the cam swap.
Old Jan 6, 2007 | 03:54 AM
Dustin 98TA's Avatar
Do some research on other peoples setups. You have to decide what your goals are with the car and go from there. The bigger you go the more power you will make but driveability will suffer.
Old Jan 6, 2007 | 04:39 AM
seabirdak's Avatar
See I'm not the only one... lol
Old Jan 6, 2007 | 06:59 AM
VINCE's Avatar
Shorty Director
If you dont plan to go over 600rwhp I would suggest something in the dual pattern category. If you are talking a 346ci I would go with either one LPE's cams or just choose anything from a 220 to 226 cam with a LSA of 113 to 117..
Old Jan 6, 2007 | 01:34 PM
spy2520's Avatar
what about if you want to make decent power off boost as well? like if you are doing a "PROGRESSIVE" install (meaning its gonna take a while) and you dont necessarily want to have a mild cam.
what i mean is if 220-226 witg 113-117 lsa is the first tier, whats the next level up? nothing crazy though...
or is 226 on thw big end for a 346ci that doesnt plan on running 7s in the 1/4?
Old Jan 6, 2007 | 03:00 PM
engineermike's Avatar
Guys have run deep in the 9's at over 150 mph with 218 - 226 on the intake.
Old Jan 6, 2007 | 03:20 PM
Country Boy's Avatar
Senior Member
My LPE GT2-3 does good and it drives and idles just like stock.
Old Jan 6, 2007 | 04:10 PM
seabirdak's Avatar
I was looking at the Lingerfield cams yesterday they look pretty good.
Old Jan 6, 2007 | 07:17 PM
spy2520's Avatar
wow, so a 226 will give you decent power NA, and be a really good turbo cam. that narrows it down alot...
i do have a question though...
would you opt for a smaller cam like a LPE GT2-3 (207/220 .571/.578 118.5 CL)
or would an LPE GT11 (215/231 .631/.644 118 CL) work just as good with a turbo, but give more performance NA?
the reason i ask is because i'm slowly but surely building my car up to accept a turbo kit, so i dont want to do something that will only run good on boost.
