Close to engine/turbo time
Old Jan 9, 2007 | 04:16 PM
Phil99vette's Avatar
7 Second Club
I'm in the same boat, 402-404 with a big turbo and glide. I can't decide between heads, I'd really like to get one with a .750+ deck.
Phil
Old Jan 9, 2007 | 04:49 PM
Snyper's Avatar
I know a outlaw 10.5 guy here that has a mustang with a 38x ci and twin t88's. you can go bigger
Old Jan 9, 2007 | 05:40 PM
Slowhawk's Avatar
LS1Tech Sponsor
Originally Posted by ty_ty13
iron block, big single, methonal, l92 heads, make your own intake (sheet metal), BS3, 190 injectors, glide, 9''-3.55, 31'' tires..... YUMMY!
You think just like me I thought L92 heads with the GMMP intake.I'll through them on box/stock with some springs and see how they do
Old Jan 9, 2007 | 07:54 PM
NA$TY-TA's Avatar
awsome.............
Old Jan 9, 2007 | 08:27 PM
ty_ty13's Avatar
7 Second Club
i'd like to see what a "cheap" (if that can be used in a FI section) build could do....
lol... im calling a 408 with l92 heads and a 90+mm turbo cheap... i think i've gone off the deep end...
Old Jan 9, 2007 | 08:49 PM
Slowhawk's Avatar
LS1Tech Sponsor
Originally Posted by NA$TY-TA
I like where ya started with your post......
Don, id love to see what you can do with some L92 stuff since a 4.03" bore is needed...... Iron block.... Buy the heads and the intake TB for $1500 from GMPP and add double springs and show people what that can do at the same time.....
Stock PCM with 3 bar??? or BS3??
I like the Glide with a 9" and 3.50 gear and what ever tire u decide.......
It will be stock PCM. I'll probly play with a 2 bar then switch to 3 bar.I like testing. I know 950rwhp can be made on a 2 bar 408ci setup.Might see what that will run first.Should go low 9's,high 8's easilly enough.(depending on weight ect). Then add some boost. I have time and have no problem going to track rentals
The car will have a powerglide,transbrake setup. Right now the rear has 3.73's(because it was suppose to be Procharged) which I'll try.I know my car will take 29" tires which might help.Also it will be running DR's.
Old Jan 9, 2007 | 08:51 PM
Slowhawk's Avatar
LS1Tech Sponsor
I'd like to see what a cheaper setup can do.I've seen way too many high $$ setup's and the customers not happy. Whats the worst that can happen? Heads don't work? No big deal. I fully expect to build 2 shortblocks so there is no downtime when they pop.
Old Jan 9, 2007 | 08:59 PM
DanaliHD's Avatar
i've got it all figured out brotha. 408 with ETP 245 heads, ITS 80mm turbo, turbo zone single turbo kit, speed eng fuel system.
all that can be yours for the low, low, low, low price of $30,000.
just make sure you takes all the **** out of my truck before parking it on the train tracks.
Old Jan 14, 2007 | 07:46 PM
8ALTNG's Avatar
Sleeper Combo:
Front mount 76mm on a fully forged 4.8 liter. Very timmid till the rpms get to 6800 then watch out
I think I could even get you hooked up with the engine for a good price...
Old Jan 14, 2007 | 08:38 PM
99Z28LS1's Avatar
i dont know much about cars and what good combos would work, but i would do the 408 with twin T88's or something, seeing as how you know how to fab up yours own stuff, get crazy
Old Jan 14, 2007 | 08:42 PM
SSilverSSurfer's Avatar
370 and a huge single ftw
Old Jan 14, 2007 | 09:32 PM
  #32
Slowhawk's Avatar
LS1Tech Sponsor
I love the answers here
It looks like a 408ci with a 91.5mm setup for now.I'm sure that will easilly hit low 8's and possibly faster.
I think it will look good with truck manifolds
Old Jan 15, 2007 | 04:05 PM
  #33
JS's Avatar
JS
414CI w/twin 88's
Old Jan 15, 2007 | 04:28 PM
  #34
Jammer's Avatar
I like the 408 with twins, but I am slowly buying into the shorter stroke for boost idea//// I have the 408 with twins, and if I had to do it again, it would be a ls2 bored, with stock stroke and a big single...far easier in my eyes... but those ls2's cost too much!
How do you have all this free time???? LOL
Old Jan 15, 2007 | 07:41 PM
  #35
02SSLE's Avatar
402 91 is my vote
Old Jan 16, 2007 | 05:22 AM
  #36
Slowhawk's Avatar
LS1Tech Sponsor
The sad part is that I don't Just have to make time,if it's done before summer it would be a miracle
Old Jan 16, 2007 | 06:18 AM
  #37
cablebandit's Avatar
370 iron with stock 317 heads with springs...ls6 intake and a 91mm. If you end up popping the shortblock, you may damage the heads/crank so it would be nice if they were "disposable". Then you can go back with shortblock #2....more cubes.....l92 p/p (a couple of cnc programs should be out by then) l76 intake. First motor is a little cheaper and enuff power to get the car shook down. Then you can progress to new motor and more power
Old Jan 17, 2007 | 10:19 AM
  #38
98Z28MASS's Avatar
So what was the final decision Don? I say go for something that hasnt been done before, vtec with twin turbonators!
Old Jan 17, 2007 | 12:56 PM
  #39
PurEvl's Avatar
just take my drivetrain and whatever else and be done with it, you can have it for free, we just need to get mine back to stock well enough to trade it in
Old Jan 17, 2007 | 01:05 PM
  #40
Bryan @ Speed Inc.'s Avatar
on the cheap gets my vote... stock crank 370 motor w/ the truck manifolds, l92 heads and intake.
holy ****, that's so affordable even *I* might be able to swing it. ... wait, but that's not including the 91.5 turbo. lol
